View Full Version : Performance & Maintenance
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
  1. Help my car doesnt pass smog !?!?!??!
  2. SC400 tranny swap?
  3. Reading trouble codes in pre-OBD II (pre 1996) SCs
  4. Heater problem, please help
  5. Anyone got a repair manual?
  6. w58 tranny swap and speedo not working!
  7. Check Engine Light Issue
  8. 94 sc400 shakes when i drive
  9. Tune up causes A/C heat to not work...
  10. Help with Aristo base map for Aem
  11. SC400 - low speed stalling
  12. Info on SC400 vvti w58 swap!
  13. Good question on sc400 vvti a650e tranny
  14. SC 300 Heater Putting Our WARM Air
  15. intake smoke...um yeah lil help please!
  16. HELP! 1JZ overheating in boost
  17. Aftermarket Transmission Filter?
  18. SC400 Cold weather operation.
  19. 1UZ thermostat?
  20. aristo in sc300 problem
  21. 220,000+ maintenance on recently purchased car.
  22. PLEASE HELP!! Starting problem;SC400
  23. SC400 stalling issues
  24. Exhaust Ideas Gents
  25. need help..where do these all the vac lines go? na-t with ttmanifold project
  26. HELP: Puzzled by my car
  27. Hi, new here, first SC300, have a few quick ?s for everyone
  28. Distributor...
  29. Best aftermarket parts
  30. EGR71 code will not clear trac/check engine
  31. how do i know its my alternator?
  32. Another Bad Noise
  33. Help with motor swap.. non-turbo
  34. Mkiii r154 vs soarer r154 shifter feel
  35. is it normal?
  36. water leak
  37. Pics of my 1j that came in this morning
  38. Mechanic says I may need new transmission - you agree?
  39. Sc400 drag car
  40. Screeching noise after seafoaming my car
  41. diy torque converter request...
  42. Prestolite Plug Wires
  43. HELP WITH RPM !! 1995 sc400
  44. Engine Hesitation at 5200 rpm
  45. 1jz wiring blues
  46. Stripped bolt with pic, suggestions
  47. You've got to be kidding me!? An Electric turbo?
  48. Timing belt install, but it wont start!
  49. Automatic Stalling Out? Waitwut?!
  50. SC400 W58 Swap in progress
  51. HELP - '92 Lexus SC300 idle problems
  52. VVti question
  53. Any automatic drivers ever had this PROBLEM
  54. PLEASE 92 Sc300 automatic transmission not changing gears
  55. *94_Soarer's Auto to 5spd Swap*
  56. How do I remove the alternator on my 98 SC400 without removing power steering pulley?
  57. My SC just took a dump. Any suggestions?
  58. r154 bellhousing??
  59. jdm tt question
  60. car jerks while accelerating or decelerating
  61. Help!, 1JZ-GTE vvti into an SC400
  62. HELP. Changed trans mount now Power Steering Overflows.
  63. Clublexus, any idea what's wrong with my car?
  64. Maintenance Schedule for 98 SC300?
  65. Spark plugs, wires
  66. shift solenoids
  67. List of bolt in rearends?
  68. Is it even possible to remove the 400's PS pump?
  69. All 99 SC300 owners Air intake Question
  70. Car has lost power, Cats glowing... All bad!
  71. Metal shaving in the transmission fluid is good?
  72. Has anyone ever installed headers on a vvti sc400?
  73. 5spd conversion
  74. Motor mount question for you 2jzgte'ers
  75. A/T shifter Knob sakes while riding
  76. MagnaFlow 99175HM?
  77. 300-350 hp with 1uz
  78. Automatic trans gear indicator not working properly
  79. Making Power in California
  80. Automatic Transmission -cooling feed/return lines
  81. Sc300 automatic problem
  82. Anyone know where where these wires on IK2 go?
  83. About to buy a 1jzgte
  84. coolant loss searched
  85. 5spd Problem =(
  86. ecu
  87. Hesitation / sputtering around 1500rpm
  88. 1jzgte Engine Harness
  89. Future SC300 owner with questions, performance and some others
  90. IMF SC400 Headers GB $399!
  91. SC400 Trans whining and clunks
  92. Lets Discuss - 3.23 Gears in MY SC400
  93. Need Help With My SC300!!!
  94. question.
  95. Radiator replacement help
  96. should i run 2.5 or 3 inch piping? help me order real fast.
  97. Need quick verification
  98. High Mileage concerns
  99. R154 shifter Question(please help)
  100. SC400 rough idle, off idle fine, then doesnt start one morning
  101. Gas tank drain plug location ?
  102. 1jz pistons?
  103. Resonators
  104. s4s hybrid kit owners post.
  105. working on tt manifold on ge lower runners
  106. working on tt manifold on ge lower runners
  107. TH400 In an SC300.. Question on Install.
  108. gs300 axles on sc300?
  109. Newbie to JDM need help
  110. Intake adapter and k&N filter #0810
  111. VSS no.1 code 42
  112. 1JZ running good, sorta...
  113. Noob ? GE GTE Questions
  114. 1995 SC400 Overheating problem. Need solution HELP!
  115. Upgrading alternator and battery
  116. PLEASE HELP QUICK!!! Aluminum Radiator for sc300 A/T?
  117. Loud exhaust
  118. SAFC froze now running rich...??
  119. So is 1 turbo better than 2?
  120. Aristo swap to Usdm ecm/specs
  121. Cant rev after headgasket install
  122. greddy speed cut
  123. what do ya think so far
  124. GOING SINGLE! first pics in side
  125. need help asap. weird part melting
  126. Timing Belt "O" BOI.. VVTi 1UZ
  127. Please help.. Pinouts needed 1992 SC300-2JZGTE!!
  128. What clutch should I get?
  129. Driver door won't open!
  130. Help with wiring..1992 SC300 Auto w/2JZGTE
  131. Help from you 1JZ gurus please...
  132. Water Pump replacement?
  133. 99 SC300 Transmission vs 99 GS300 trans?
  134. Question/Verification on Fuel ECU bypass wiring
  135. bulding a turbo kit need intercooler piping for the sc300
  136. sc400 custom exhaust piping question
  137. 5 spd Swap with an OBDII Car
  138. supra 550's...?
  139. yes or no question
  140. 2jzgte swap...
  141. replacing rod bearings, motor in car?
  142. What is the number of the tail light bulb?
  143. Sc400 gurgling sound/ hot exaust
  144. New Ebay Exhaust Out
  145. clutch just dropped while driving =O
  146. HELP need asap...(really means Starter Issue)
  147. in search of soarer 1jz engine harness pin out
  148. Need help with twinturbo setup !! Please !!!! Asap !!!
  149. Egr mod do i put the resistor here? picture
  150. CAR Hesittating & Loss of power!
  151. spoiler brake light
  152. More Problems!
  153. Power Steering Tube leak
  154. Transmission Upgrade (Auto or manual)
  155. Hold the exhaust please....
  156. boost my LS or upgrade to XJR
  157. exhaust swap question
  158. Looking to buy a catback exhaust
  159. Looking to buy an intake
  160. Odd Battery Problem
  161. Any interest in SC300 headers?
  162. What is this called???
  163. Checking interest for the IMF headers..
  164. which would be better?
  165. Which NGK Plugs to Use?
  166. GE block and TT head Who's got it?
  167. A340E and an A341E transmission
  168. I have got the throttle body and intake manifold off
  169. Drive Shaft Bolts
  170. Lexus warning light
  171. are these motors and trans the same ????
  172. Fellas Got a Check enging light on 98 sc400 vvti
  173. Radiator Leaking!!! LS400 part in SC??
  174. Rear O2 Sensor removal and tricking?
  175. Wtb: 1jz turbo or 2jz turbo motor !! Socal !!
  176. CEL turns on and off
  177. Need help gathering minor tune up parts SC400 98 vvti
  178. sc400 tranny to a 1jz-gte tranny???
  179. would this work?
  180. Gotta figure out why the oil light was tripped when.......
  181. Lost on the turbo size to get. Please help.
  182. underdrive pulley?
  183. Is it just me or does the a650e tranny drive funny?
  184. 95 SC400 won't fire, need help with external fuse box wiring
  185. Clutch replacement
  186. need help with auto tranny on 93 sc400
  187. Amsoil Help
  188. HELP AC doesn't work
  189. 1uz-fe (71, 76mm turbo spool)?
  190. Short shift kit
  191. Canister is leaking Gas...Please Help !!!
  192. Does anyone still use the MSD BTM?
  193. 95 SC300 won't shut off
  194. traction light flashes, check engine on. Car won't drive
  195. TT coil fitment on a na-t (please advise)
  196. Where O Where do my hoses go? W/pics
  197. AEM EMS+ JDM 2JZ-GTE help please
  198. Any Plug and PLAY standalone for aristo engine
  199. sc300 belt squeal
  200. Crank Pulley Bolt Removal?
  201. Cam Gear Cover Mod and 02 Sensor Question
  202. Squeaky Clutch 94 SC300
  203. Few questions for a Newbie (engine swap questions)
  204. Where to begin
  205. Question i'd like an answer to please (Engine Swap Questions)
  206. One simple question!!!!
  207. ge water pump on 1j?
  208. car bogging and hesitating. pls help :(
  209. I just got my 92 lexus sc400
  210. Smart people...
  211. '92 5sp won't crank, no fuel, no power door locks after installing new battery
  212. Supra flywheel
  213. 1993 SC400 Over Heating Problem
  214. 1JZ hesitation issue
  215. Difference Between 2 W58 shifters?
  216. Changed spark plugs, now car barely running...HELP
  217. supra fuel pump?
  218. results on
  219. *What car is this clutch pedal from*
  220. Code 52+55 (Knock Sensor)
  221. Camshafts...1uz
  222. Check engine light
  223. exhaust leak help
  224. 2jz-gte + w58...clutch component concerns...
  225. A few problems/diagnosing help
  226. IS300 steering wheel? what is needed?
  227. Fuel cut? clutch slippage? HELP!
  228. knock sensor help!!!
  229. Do you trust this TURBO MANIFOLD?
  230. Anyone run a surge tank??
  231. Crank Pulley
  232. NEED help >how to install GM3 bar map sensor
  233. will a mk4 torque converter fit my 1jz/a340e swapped sc300?
  234. purchasing a 97' sc300 five speed manual, motor swap help
  235. 1jz auto
  236. Head Game Whats The Difference VVTi Head VS. Non VVTi Head
  237. Short Shifter
  238. Car missing and stalling
  239. JDM 1jzgte california legal
  240. washed my engine bay, but the problem is not what you think, help please
  241. Mounting a MKIV Stock Intercooler
  242. W58 and 1jz
  243. Diff centre replacement
  244. Megasquirt II v3.0 Q's & A's
  245. Trans swap question
  246. 98 2jzge vvti into an 94 sc3
  247. 1jz/2jz with emanage blue install direction
  248. Speedometer Issue
  249. So has anyone tried installing injen's intake on 96+ SCs?
  250. where to find 1jz distributor?
