Pulsing Sound above 70 MPH
Old Aug 18, 2021 | 04:31 PM
perfctreig's Avatar
perfctreig
Default Pulsing Sound above 70 MPH
Unfortunately, it is rare I get to drive my SC faster then 70 miles per hour. When I do, I'm noticing a "pulsing" sound from either the engine or the tranny or the wheels or the exhaust. I took a video of it the other day while on a fairly open freeway. Any idea what this is? Again, it only occurs when I go above 70 MPH.
Old Aug 18, 2021 | 07:57 PM
Brownd3max's Avatar
Brownd3max
Default Pulsing sound...
SC400 Pulsing Sound at 70😕+ - YouTube
I'd check the ATF, tires, all wheel bearings, then drive shaft bearings/U-joints, in that order, and verify the diff has enough of good oil in it.
Old Aug 18, 2021 | 08:11 PM
perfctreig's Avatar
perfctreig
Sounds like a weekend project. At least the tires are new (about a week) so I can rule them out.
Old Aug 18, 2021 | 08:50 PM
Brownd3max's Avatar
Brownd3max
"At least the tires are new (about a week)..." Wait... new tires you say? Hmmm.... raise the car with tires dangling. Spin them, one at a time, as fast as you can by hand. Hold up a straight edge ruler real close, parallel to the tread and check for "out-of-roundness" and/or any bumps/bulges. You can have a tire balanced ok but still be out of round. Causes weird things..
Old Aug 19, 2021 | 08:02 PM
perfctreig's Avatar
perfctreig
I'll take it to my mechanic (since I'm not named, Tyler Hoover and don't have a lift at home) and let him take a look.
Old Aug 21, 2021 | 08:49 AM
jba7553's Avatar
jba7553
I believe the sound you hear is the same as the one i have experienced on a couple of sc400 that i have owned. I eliminated the noise by replacing the center drive shaft bearing.
Old Aug 23, 2021 | 11:14 AM
RudysSC's Avatar
RudysSC
You may spend all weekend trying to find this, however, the easiest solution will be to get that thing up on a lift, start spinning things, and that'll give a good trained eye a quick answer as to what's causing all of your noise. Best of luck!
Old Aug 24, 2021 | 11:14 AM
perfctreig's Avatar
perfctreig
Well, by coincidence, I was stuck in traffic behind a broken-down semi yesterday. Also the fan relay switch for my e-fans died, so my engine started overheating. I took the car into my mechanic to replace the relay.
While there, I had it on the lift and took a look. Neither of us found anything abnormal. He even drove it up to 90 MPH to see if he could replicate. Nothing at the moment.
I'll chalk it up to a gremlin and monitor it.
Old Aug 25, 2021 | 06:36 AM
RudysSC's Avatar
RudysSC
Fair enough! Glad you got it checked out.
JAYCRAY
Aug 2, 2019 08:20 PM
pbateson
Jan 17, 2017 09:57 AM
odj1989
May 13, 2011 01:53 PM
MT Photo
Feb 27, 2008 05:30 PM
LexusRules
Mar 22, 2001 12:33 PM
