Traction light code 24
Old Jul 19, 2021 | 08:43 PM
ostap20's Avatar
ostap20
Default Traction light code 24
Hello guys my Lexus has been cutting power and not building rpm over 2k rpm. I scanned codes and the check engine is flickering which I assume means no codes there, however the traction control is giving me a weird code. The light flickers go like this: 2 4 5.
I’m assuming it’s code 24 since they don’t go all the way to 245. Anyways that code is “Open or short in sub-throttle actuator circuit” any ideas on how to solve the issue? I thought the tps could definitely cause rpm not to build but I have no clue what this issue is.
Old Jul 20, 2021 | 12:57 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
check the second tps if you have traction control, could be the code for that.
Old Feb 5, 2022 | 09:29 PM
ConverseB's Avatar
ConverseB
Default You ever figure out the issue I'm having same problem
you ever figure this out
jasawh
Feb 24, 2018 06:29 AM
farklspark
Mar 30, 2017 06:13 PM
diverchris
May 1, 2014 01:20 PM
CallmeQ
GS - 1st Gen (1993-1997)
Sep 26, 2009 12:19 PM
opsta
Jul 27, 2006 09:33 PM
