Camber Help Front and Rear
Old 12-16-14, 08:31 AM
WylieKylie
WylieKylie's Avatar
Originally Posted by Rudebwoy30
Can anyone else confirm that the 2IS comes with adjustable toe from factory??
Yes. Via threaded tie rods in the front and eccentric cam-bolts in the rear. The real issue is in the rear if you:
A) Run out of adjustment
B) Want something precise, the cam bolts are a nightmare for fine adjustments.
Old 12-16-14, 09:01 PM
Rudebwoy30
Rudebwoy30's Avatar
Thanks Wylie Kyle. WIll be ordering myself some christmas presents very soon Camber arms front and rear Figs lower bushings and F sports Sways
Old 12-17-14, 12:51 AM
uytpiconsw
uytpiconsw's Avatar
ive had the car aligned before. But dont you notice the uneven wear by time the tire is already bad.
Old 12-17-14, 08:15 PM
AutoSexy13
AutoSexy13's Avatar
If you can't adjust toe then how do you suppose an alignment is done?
bayawak69
Suspension and Brakes
15
08-06-15 05:47 AM
i2fat
05-11-15 03:14 PM
ekrebs
01-15-09 06:51 AM
SPEED&ECO.
01-28-07 02:40 PM
raul
IS - 1st Gen (2001-2005)
11-08-01 04:00 PM
Quick Reply: Camber Help Front and Rear
