Front Camber Kit
Old Apr 19, 2015 | 11:14 AM
i2fat's Avatar
i2fat
Default Front Camber Kit
I recently lowered my car with RSR Downs and the rear camber / toe seems to be in spec.
Rear Camber: -1.6 and -2.2
Rear Toe: .13 and .12
However, my fronts seem to be out of spec:
Front Camber: -1.4 and -1.2
Front Toe: .05 and .03
Does anyone know if they sell front camber bolts? or anything I can do to adjust the fronts?
Old Apr 21, 2015 | 11:27 AM
ExSrAaron's Avatar
ExSrAaron
Camber's good. Keep it the way it is. Out of spec but within the range most ppl like on performance cars (-1.0+). Tire wear will be slightly worse with higher negative cambers though. Personally, I would want the camber/toe to match left and right more than anything.
I also want to know what options are available for camber adjustment (more negative camber) . Ball-joint replacement is the only options? Can anyone confirm this?
Old Apr 22, 2015 | 11:12 AM
JB5674's Avatar
JB5674
http://shopfigs.com/v1/index.php?rou...tegory&path=89
check this link out....
likewise, the dealer told me we naturally have some inner wear due to camber form the factory. Its more or less expected to happen sooner or later aka a performance car.
Old May 7, 2015 | 08:25 PM
osh3is350f's Avatar
osh3is350f
Pretty sure T Demand has them. Kinna expensive though
Old May 7, 2015 | 08:48 PM
anthonys2r's Avatar
anthonys2r
Do you have a link for that? Can't find them on a google search..
Old May 7, 2015 | 09:37 PM
osh3is350f's Avatar
osh3is350f
Sorry no I dont. The shop owner working on my car said that they offer them and he can get them. You might have to contact T Demand directly
Old May 8, 2015 | 04:48 AM
is3501007's Avatar
is3501007
I also was curious if this is okay? Since I got an aligment just about 2 weeks ago since I wanted an even camber wear.
Old May 8, 2015 | 05:19 AM
Diesel350's Avatar
Diesel350
Looks ok for now but as soon as some quality front camber arms are available I would buy them. You'll probably have some premature tire wear until you get that front camber back in spec.
Old May 11, 2015 | 03:14 PM
breezytint's Avatar
breezytint
Check this thread out.
https://www.clublexus.com/forums/is-third-generation/781918-camber-kits-for-2015-is250.html
bayawak69
Suspension and Brakes
15
Aug 6, 2015 05:47 AM
Spamboi
Jun 18, 2015 08:39 AM
iNS0MNiAC
GS - 1st Gen (1993-1997)
Nov 18, 2008 12:48 PM
FutureGS400
Aug 25, 2004 01:44 AM
