Stock HID question
Stock HID question
Ok so I have a 2008 is250 it came with hids because the headlights move up and down adjusting when I start the car. Who ever had it before put a aftermarket bulbs because the factory are so expensive. One side is white the other is blue. I called lexus and they sell a cheaper kind of bulbs for like 38 dollars a piece. Wondering if they are any good. Right now I'm having trouble seeing. What should I do?
Toshiba-Harison or Philips are usually what I recommend for OEM replacement.
You can find Philips D4S bulbs online for about $35 each (these used to be the OEM bulbs Lexus used).
You can find Toshiba D4S bulbs online for about $40 each (these are what Lexus now uses).
Jeff
Jeff
Tech Info Resource
I bought two Philips Xeneco D4S from Amazon because I had one shutting off randomly. The bulbs I removed from my 2008 IS-F were Philips Xeneco bulbs. I've had zero issues and they have identical color temperature.
TJW98LS
12
01-10-09 05:25 AM
