Hi guys, i have a question for all of you who have or had the Vossen wheels installed on your IS, or could be a different wheels but same offset as mine, right now i am having 20"x9" with 32+ offset on my front, and wearing 245/30/20 V12 K120 and i dropped on F-sport spring and shocks , my only driver rub when i hit a small slope or bumps as any speed unless i drive 10 mph it rub right at the bumper and fender bracket, it shredded some meat of my tire too, if i down side the tyres to 225/30/20 would it help? , it is very crazy it rub just on the driver side, even i have a passenger but that side never rub.
Thanks guys for the help, but this afternoon ran out to my car and used the sharp blade cut off the plastic wheel liner to where is rub, and used the dramel drill grand some of the bumper tab and fender metal down a little and now is no more rub
Yep, you can cut away quite a bit of that bracket if you need to. Just drill a new hole for the screw, then cut away as much of the bracket as you can.
Thanks guys for all the tips, but i think my front caster is shift forward? Is it the reason for that driver to rub and the passenger isn't? I know 245/30/20 is big for the front, but why is only rub on the driver side? Not both
