Suspension enhancment
https://www.etrailer.com/susp-2004_Lexus_GX+470.htm
Found this on etrailer.com Its listed as a suspension enhancement available fothe gx470 front and rear suspension. Basically it replace the standard bump stops for the front and rear. Sounds like it might insulate the bumps that we get when driving. Has anyone seen this or know anything about them They are kind of pricey for about $ 100.00 per wheel adds up to $ 400.00 for the parts plus labor. In theory it sounds plausible !!!
A lot of Taco and 4Runner guys run wheelers offroad and timbren bumpstops...mainly front though but there are a few 4Runner guys running them in the back. Whether they work well w/ our airbags / shocks I don't know.
I ordered them this morning. I found a 5 % coupon off on line so I was able to use it also free shipping net cost
$ 373.00 Will ship mid February. I wont install till its warm. I have to mount chrome gx460 rims as well. I am going to buy a portable battery powered impact tool. Any one got advice on what impact tool to buy. I don't want to go to harbor freight I would like to get more then one time use of it.
I have this kit: Milwaukee 2654-22CT
- specs can be found here: http://www.milwaukeetool.com/power-t...less/2654-22ct
Looking forward to see if those bump stops work.
If you're wanting an impact for suspension work I'd recommend the 3/8" Milwaukee 2654. It's handled everything and anything I've thrown at it. It has 3 settings, 30ftlb., 75ftlb., and 200ftlb., so you can use it on smaller fasteners too.
Most only do the front when they're off-roading so I agree I doubt they're do us any good for onroad driving. I've never bottomed out up front.
I thing the rear bump stops are ok...the main problem is the ride height system itself making us bottom out. If you trick the airbags and raise the rear 1/4" - 1/2" it'll fix the bottoming out problem. I lifted it 1/2" and it was perfect. You might not even have to lift it that much.
All you have to do is remove the rear tires and the brackets are right there. There's only 2 bolts holding each bracket in place. Just remove the bolts, install 1 or 2 washers on each bolt and screw it back in. It's a very simple fix and best of all super cheap.
For anyone bottoming out try adding washers to the bracket, it'll make a world of difference! I had some free time today and picked up some .20¢ 8mm washers from Ace. The ride now is like a night and day difference. I no longer bottom out over speed bumps. I can take them as fast or as slow as I want and the airbags and Bilsteins soak the bumps right up. I still slightly bottom out on that one dip but it's not a normal dip and pretty much every other car bottoms out too but the difference now is it's not jolting as before, it's tolerable, even my wife was amazed and she said it's perfect.
When my front Icon coilovers get here in the next week or two I'll raise the back even more and then we should be literally riding on air. It's amazing how just lifting the rear 1/2" makes such a huge difference.
Parts needed:
I added 2 washers to each of the 2 bolts and I got 1/2" of lift.
Parts needed:
- Washers: 8mm: 1 washer = 1/16" thick / 2 washers = 1/8" thick
- Bolts: M8 (8mm) coarse thread / 1.5" in length; you can use 1" but I went w/ the longer since I'm going to lift it more once I get my coilovers on. Even 1.5" in length will screw all the way into the frame without any washers so you're fine using longer bolts.
Threxx
Suspension
06-05-06 01:14 AM
