GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
'05 GX Side mirror not returning to position
Old 02-07-17, 12:14 PM
ddoo3105
ddoo3105's Avatar
Default '05 GX Side mirror not returning to position
Hi all,
I recently started experiencing a situation in which my passenger side mirror does not return to its original position after shifting from reverse to park/drive. When shifting into reverse my mirror dips as expected, however, upon shifting back to drive or park the mirror stays dipped. The motor appears to be fine since I can adjust the mirror up to its original position manually. Any thoughts on what's going on?
Thanks!
Old 02-07-17, 12:36 PM
lesz
lesz's Avatar
Received 1,010 Likes on 691 Posts
I've seen multiple threads from people with various Lexus vehicles who had the same issue, and, in most cases, the cause of the problem was that they had accidentally and without knowing that they had done so changed the mirror position either when it was in the normal position or in the reverse position.
If that is what happened in your case, the following steps should correct the problem. First, with the car running and the transmission in park, set the mirror to the normal position that you want. Then, shift the transmission into reverse (and, obviously, keep your foot on the brake), and, then, set the mirror to the position that you want it to be in when in reverse. Then, check to see if that solved the problem. If it didn't, something else is the cause of the problem.
See this thread on the ES forum about a similar problem.
https://www.clublexus.com/forums/es-...tilt-down.html
Old 02-08-17, 05:59 AM
ALAN553
ALAN553's Avatar
may be the actuator/motor in the mirror , i replace both on my 04 many years ago...there are threads here somewhere on the problem, part number and instructions...pretty easy
b2884987
RX - 3rd Gen (2010-2015)
04-22-19 06:36 PM
5PM
11-16-15 04:21 PM
memokc
08-04-15 06:17 AM
RA122022
06-05-12 10:16 AM
DarkknessD
09-05-10 08:34 AM
Quick Reply: '05 GX Side mirror not returning to position
