Finally decided to do a retrofit on my 02 GS and after some research found that these are the popular ones. Just want to get some input on this two projectors since I cant decide which to get. Also, do any require extra alteration(other than Luxury Mod brackets) like shaving or trimming inside the headlight housing?
SC300JZ has a diy on here. I have the fxr and followed his guide. Luxury mods has instructions on the website and I followed that as well. I had to trim the headlight bezel where the turn signal is housed. I just used a dremel.
I'm not sure how the m35/45 output are, but the fx-r are amazing. I have a DIY somewhere on here as tiger4life mention. You have to shave the bezel. Other than that its plug and play.
^ thats true, thats one benefit of the m45 it fills the headliight. I'm running e46-r extended shrouds and it still doesn't cover the gap. but its good enough.
i currently have the M35/45 retros, like mentioned above they do fill up the headlight very nicely and the output is good, if you look into my threads i have some pics of the cutoff after a little bit of modification. and the M45 are pretty much plug and play with the luxury mods bracket didnt have to cut into the bezel
