This happened today!!
Synthetic oil is just slicker at all temperatures especially cold temperatures. They tend to fall through the cracks more easily. U can use them interchangeably. If you don't notice consumption then ur engine is still tight!
If you have looked underneath the engine and carefully examined the whole motor including valve cover gaskets, engine seals etc for leaks.
Then the next thing to check would be the exhaust and see if your burning that oil. If you're burning the oil then you may have carbon building up in the rings. If that the case you might get away with pouring seafoam directly into each spark plug hole, temporarily put back the spark plugs and let it sit over night. Then with compressed air blow out all the seafoam in the cylinders
tabraha
11-14-04 10:15 PM
