ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Trunk lid misaligned
Old 04-03-14, 06:36 AM
acat1234
acat1234's Avatar
Default Trunk lid misaligned
I have a 2007 es350. I hauled a bike in the trunk yesterday, obviously with the trunk lid firmly tied down. Went over a speed bump, I thought slow enough, but there was a thump from the back. Later that day I noticed the passenger side was up around 1/4" at the upper edge close to the rear window. Checked with a hose and it leaks.
Is there any way to realign it? Does anyone have diagram of rear trunk lid and mechanism.
Thanks in advance!
Old 04-03-14, 10:45 AM
SICK350
SICK350's Avatar
Pictures please?
I'm thinking you bent the lid but a good way to tell if it shifted is to remove the lining on the lid and you should be able to see bare metal where the hinges are bolted to the lid if it shifted. If this is the case loosen the bolts and realign to the paint so no bear metal is showing and slowly close the lid to see if that fixes the problem. If you have a gap on one side when it's closed and it sits higher then the fender it's probably bent unfortunantly. Hope this helps and works for you.
Old 04-04-14, 07:18 AM
acat1234
acat1234's Avatar
Thanks for the reply. Checked around the bolts and they looked as if they never moved - no bare metal. Would submit a picture but I am new to site and haven't figured out how to.
Hopefully this can be fixed without replacing the trunk lid.
Thanks Again
Old 04-04-14, 09:33 AM
nevernu
nevernu's Avatar
maybe this is useful
File Type: pdf
File Type: pdf
Old 04-04-14, 09:41 AM
acat1234
acat1234's Avatar
Thanks for the diagrams. Definitely helps me visualize how the trunk lid can be adjusted. Do you think I could just loosen the hinge on the side that is high to lower it around 1/8 to 1/4 inch?
Again, that's for the info.
Old 04-04-14, 09:54 AM
nevernu
nevernu's Avatar
i guess thats the idea, but check that the bolt is adjustable not the centering bolt otherwise u will have to replace it too before u can adjust
Old 04-04-14, 03:30 PM
acat1234
acat1234's Avatar
My real issue is to prevent water entering the trunk area. I am not real **** about gaps! I considered building the top of the trunk gasket up with Gorilla Tape applied to the rim of the trunk lid which contacts the gasket.
Old 04-04-14, 03:58 PM
nevernu
nevernu's Avatar
I would think a properly adjusted trunk would prevent leaks. What's the problem with adjusting/replacing a few bolts?
Old 04-04-14, 05:46 PM
SICK350
SICK350's Avatar
Duct tape has no place on a Lexus, I would take it somewhere and have it looked at.
Old 04-04-14, 10:00 PM
acat1234
acat1234's Avatar
Five thumbs, no fingers! Seriously, I am not that mechanically inclined but willing to tackle some projects. Do you have any parts diagrams illustrating the items to be removed/replaced in the instructions? Sorry to be so dense, but.....
Thanks in advance.
Old 04-05-14, 05:06 AM
SICK350
SICK350's Avatar
Save your self the head ache and have it fixed by a professional or a friend who knows cars.
Old 04-05-14, 07:01 AM
jagtoes
jagtoes's Avatar
Not seeing a picture but based on what happened you have bent something . You may or may not be able to adjust out the problem . I would take it to a repair shop and see what they say. If all of the bolts are tight then readjusting them will not fix the problem.
Old 04-09-14, 05:14 PM
acat1234
acat1234's Avatar
Problem solved. Must not have been bent that bad-just grabbed the high corner and pulled down. Back to acceptable tolerances. Regarding comment that duct tape has no place on a Lexus, I agree-do not want to give duct tape a bad name.
Seriously, I have owned this 2007 ES 350 since brand new. My opinion after 6+ years is that it is an over-hyped, over priced Camry. My 2001 Olds Aurora (V8) was a much better driving experience.
Old 04-09-14, 05:41 PM
LexBob2
LexBob2's Avatar
Approaching 7 years (8 model years), you could get out of the ES and into something different while it still has a decent trade-in value.
Old 04-10-14, 04:49 AM
SICK350
SICK350's Avatar
Ya like a Honda civic Lexus hater.
Quick Reply: Trunk lid misaligned
