LS460 Wind Noise Fix (merged threads)
Thanks
I now have my car back from the dealer finally. Both front windows were swapped and because we had some rain here today I can't tell yet if the wind noise problem is fixed, but I can tell one thing: The service performed was flawless. Absolutely no scratches, nothing loose, they did an **excellent** job. This experience was completely transparent for me, it looks and feels like the car has never been in the shop for the window fix.
Friday I'll post my final report here, I'll drive to the tint place (freeway included) to get the front windows tinted again.
They also performed 2 other ECU updates, one for knocking on specific conditions and the other for the hesitation on take off.
Lexus service rocks.
Did you notice that the Security system labels are not on the new glass?
Look through the post dated 7/13/2007 and you will see the part list that I posted with part numbers except for the insulation kit that has no part number at this time.
No, its not in the VIN. Open your driver's door and on the bottom right you'll see the manufacturer's plate. In the upper right hand corner you will see the date of manufacture expressed in month and year, e.g. 05/07.
QTY---------------FP NUMBER -----------Description:
08...................... 75562-30070 ............... Clip. Roof Drip S
01...................... 75545-30150 ............... Clip. Windshield
01...................... 75546-30100 ............... Clip. Windshield
06...................... 90269-A0006 ............... Rivet
01...................... 68102-50200 ............... Glass Sub-assy. F
01...................... 68101-50200 ............... Glass Sub-assy. F
"Noise confirmed during previous test drive, wind buffeting noted from LH front window. Wind leak also noted from driver's door area.
Removed necessary parts from driver's door to install specified foam insulation per area FTS for wind leak. Installed laminated glass to minimize wind buffeting from LH front window. Test drove after repairs and verified effectiveness of operation. Performed same repairs on RH front door."
Again, Lexus of Seattle did an **excellent** job, I'm a very happy customer.
Well my shifter came loose (cheap part) and the "B" pillar cover is going to be replaced and the outside temp guage is not reading correctly.
