How Often Do U Do maintenance wk on ur LS???
Old Mar 7, 2007 | 11:18 PM
CLuv's Avatar
CLuv
Default How Often Do U Do maintenance wk on ur LS???
Maintenance work like Oil changes and things of that nature.....
1. Every _____Miles???
2. Every_____Months???
And......do u get it serviced ONLY @ Lexus or other auto shops
www.myspace.com/CLuvRnB
Old Mar 7, 2007 | 11:22 PM
Thermactor's Avatar
Thermactor
once a week I take a peek under the hood and covet my own engine
Old Mar 7, 2007 | 11:29 PM
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
whenever it tells me to
Old Mar 8, 2007 | 08:00 AM
CLuv's Avatar
CLuv
Now thats some deep azz ish.............@ thermactor & puredrifter
Old Mar 8, 2007 | 01:57 PM
steveski's Avatar
steveski
I have used Mobil 1 SYN and extended filters since 96 and change ONCE each year. However, if I exceed 20,000 miles I will change it then. Great to see the look on the tech's faces when they hear this I have 183k miles and it is perfect mechanically. However with std oil maybe 3000 - 5000k n=miles.
Air filters every 4 to 6 months or as needed.
Old Mar 8, 2007 | 03:26 PM
19psi's Avatar
19psi
i follow the factory maintenance schedule.. .of course i just got this car, so i immediately flushed coolant, trans, power steering and oil. still have to do the rear diff... i get it serviced only by a lexus certified tech, who also happens to be me!
Old Mar 8, 2007 | 04:08 PM
steveski's Avatar
steveski
Good point to use the manual specs - you being a mechanic has got to come in handy
Old Mar 8, 2007 | 05:36 PM
RA40's Avatar
RA40
About every 7-8K miles the oil.
15K miles, coolant and thermostat and check air filter.
2 qt drain of the tranny fluid every other oil change.
Tire air pressure every 2 weeks.
Basically, put gas in it and drive.
warminwisc
Dec 1, 2017 08:01 PM
vital
Feb 8, 2017 06:27 AM
daryll40
Nov 22, 2011 01:26 PM
daryll40
Apr 20, 2010 05:51 PM
Lzam
14
Aug 20, 2008 10:33 PM
