uas bags on stock struts?
Old Jan 6, 2008 | 02:45 AM
  #31
909LS's Avatar
909LS
Originally Posted by chubby
whoever said uas aerosport airsprings were for comfort? they're not even double-convoluted to make dampening easier. i work on minitrucks as a hobby and i already know the hype about mcpherson slip-over air springs. live upto the hype if you want, bellows will never be better on a passenger car compared to complete mcpherson sleeves. as mentioned earlier, all of the jobdesign cars apparently are using existing strut assemblies. ive been in a passenger car with stock shocks and bellow bags before and it feels like ****. but i'm not the one complaining. i ride with tein cst and i still get moderate ride quality. nothing spectacular, really. ride low, ride hard
the more you make your shocks work, the more stress you put on it. when u ride dumped, you'd probably be riding on shocks and not the air spring. way too much stress. you should never deflate or inflate your bag fully while driving. it just creates way too much stress on everything including the bag. either way, slip-over air springs will cut down the lifespan of the shocks by a lot. u can get away with dampening adjustable shocks to "prolong" the shocks, making it more tolerable against the bags but you'd probably go through a set of shocks at most 4-5 years compared to the normal 5+. i'll show you what i mean when i see you sometime chris. i just need to clean up my trunk cause everything's starting to fall apart =x
ooh yeah and they have the double convoluted airbag on them like you had previously mentioned!
Old Jan 8, 2008 | 03:17 PM
  #32
Balling's Avatar
Balling
yeha, im calling bull**** on the whole thing
Your ride at around 80-100 psi will be EXACTLY, like it was when you had hte spring on (maybe 70 or so for you stock guys)
I run 80PSI, and it is the EXACT same ride on my coilovers as with the spring.
In fact, its seeing track time at the beginning of FEB
Old Apr 20, 2008 | 08:36 PM
  #33
AlleyKat's Avatar
AlleyKat
This thread is confusing with both sides arguing whats best
Old Apr 20, 2008 | 09:05 PM
  #34
PK_Celsior's Avatar
PK_Celsior
im going to go tein cst and UAS. hopefully after summer. need to rack them hours at work to pay the hefty price on them . a lot of good information here.
Old Apr 21, 2008 | 01:47 AM
  #35
AlleyKat's Avatar
AlleyKat
For me its looking like tein super street then UAS later on.I was gonna use stock struts at 1st but im getting a good deal on the coils.
Old Apr 21, 2008 | 02:02 PM
  #36
AlleyKat's Avatar
AlleyKat
I called UAS today and Zach was very informative.I'll be getting a kit soon enough.
Old Apr 21, 2008 | 03:59 PM
  #37
VipDout's Avatar
VipDout
19x11.5 -51
Zack is great with tons of information ! lots of info and makes going on air easy ,
BTW from my post about AZ Compressors ... they finished it up and repaired it free ! +2 more weeks of waiting but not bad .. haha little late but I have been back up and running
Old May 11, 2008 | 09:42 AM
  #38
DriftGirl's Avatar
DriftGirl
how do u like the AZ units??
Old May 12, 2008 | 09:36 AM
  #39
golfkid777's Avatar
golfkid777
What grant said. At 80 psi, my coils feel like they did when just the spring was on there, I drive at 70 front 65 rear for a lower more comfortable stance and ride, but will occasionally pop it up to 80 for corners.
Old May 12, 2008 | 10:27 AM
  #40
T.K.O.'s Avatar
T.K.O.
I drive at 40-45 in the front and 55-60 in the rear
uas on bilstein
its whatever.
Old May 12, 2008 | 02:18 PM
  #41
mikemareen's Avatar
mikemareen
I can't imagine how long the stock oem struts will last with these bags. give it 4 -6 months at most.
Old May 12, 2008 | 02:58 PM
  #42
golfkid777's Avatar
golfkid777
Thats why I chose to spend the extra cash and get dampening adjustable coilovers that use high spring rate/short springs and were built for them. Bilstien HD struts or sport struts if driven at a decent height will give you a lot more life, but even on factory struts unless you are driving your car slammed and really hard in corners, you should be fine for a couple years.
I know DriftGirl is running bags and factory shocks on her GS she has had for a while and reports no problems.
Old May 12, 2008 | 11:33 PM
  #43
BIGGZ's Avatar
BIGGZ
Yup same here.its been 7 months and no problems.
Old May 14, 2008 | 03:44 PM
  #44
superLS's Avatar
superLS
Originally Posted by rominl
i believe the white 3gs with the job design kits have uas on stock shocks, the car is slammed. i don't know about the ls400 to be exact
https://www.clublexus.com/forums/sho...ght=job+design
LS400 is running on stock shocks with UAS.
Old May 15, 2008 | 12:23 AM
  #45
drifto808's Avatar
drifto808
im running UA kit on my ls400 with blistien HD struts...i get good drop..about half inch off the ground..ride is ok..but nothing like stock but still handles good
SoCalUCF20
Jun 21, 2019 12:52 PM
Bluegs300
Aug 22, 2013 06:35 PM
HangLoose
Oct 15, 2012 09:43 AM
MadMaxSC400
Apr 23, 2003 09:51 PM
chas
12
Dec 3, 2002 11:20 PM
