Does anyone know how to get hold of the wiring diagram for lexus ux250h 2020? I bought a control module but the wires dont have the same color so Im a bit confused. Would appreciate if someone knows a little bit more about the wiring to the headlights! Thank you!
Its the LH headlight i suppose, left hand driving headlight?
and the front right side headlight that im having a problem with. / thanks!
Didnt know i had 2 users here 😂
Would you upload a large image of the control module (headlight ECU?) with the wiring, if possible and image of the headlight with the wiring that you're trying to connect to.
This system is on a LIN and CAN bus networks and it's interconnect with many other system on the vehicle
I might have to upload multiple wiring diagrams; you can then piece it together.
thank you sir! Sorry for the late reply! I will post a picture on the headlight Ecu and cable from connector going to Ecu and cables from the car. Thank you sir
Im sorry but I just have a question since it doesnt seem to be sane wiring color combination from the connector to the headlight control module and the car cable stem do you think its possible to get it to work ? I have like 4 extra wires from the connector..
The first picture i uploaded is the color combination from the connector, and after looking att the wire diagram the red cable from car is the purple color on the connector, so I was thinking to connect all the colors that i do have and see if it works and what dont work.. is this a good idea?
Thank you for taking you time! Much Appreciated! 🙏
I tried connecting them but still no light from headlight, i got 12v out but no lights on.. i had like 4 more cables from the connector i bought
Anyone have som ideas ?
I sorted out the problem, I got the unit for left side(driver side) I managed to get everything working exept the height controller unit, Anyone have any experience of this? Does it work? Since it tried contacting the place i bought it from and they wont answer... so I though maybe its possible to get it to work as normal even though its a unit for left side?
Does Anyone have diagram for the 24pin connector for right side? Since there is 3-4 cables that has another funktion im thinking if i switch to these places on the contact it should work? Sorry for so many questions! I got it working as it should only the height control module that doesnt operate atm
I don't know if this will help you or not but here you go.
