TX Models (2024-present)
Cruise control doesn't maintain correct speed
Old Jul 22, 2025 | 03:03 PM
steveomn's Avatar
steveomn
4th Gear
Default Cruise control doesn't maintain correct speed
Curious if anyone else has seen this - after setting cruise control, it often maintains speed 1 mph lower than what it is set to. For instance if I set it to 74 mph, it will maintain 73 mph. This happens about 75% of the time with no traffic in front at various speeds.
Old Jul 23, 2025 | 05:22 AM
Stuarte's Avatar
Stuarte
7th Gear
I have a 2024 TX350 premium and my cruise control and creative cruise control does the same as yours, 1 mile less
Old Jul 23, 2025 | 06:03 AM
luckycharms783's Avatar
luckycharms783
Our TX does this also and our two Volvo’s do the same thing.
I’m wondering it’s one of two things. One is that they both use the same third party controller for cruise control. Two would be some regulation that says they can be fined if the traveling speed is higher than the set speed so they errr on the side of caution.
We’ll probably never learn the real answer.
Old Jul 23, 2025 | 11:58 AM
GSENT's Avatar
GSENT
Same on my 2025 TX.
Old Jul 23, 2025 | 07:52 PM
steveomn's Avatar
steveomn
4th Gear
Well glad to know it isn't just ours, have any of you asked the dealer to look into it or why it is that way? I've got an appointment coming up to have my ML sound system looked at and I might ask about it as well.
Old Jul 24, 2025 | 09:23 AM
Lumberg's Avatar
Lumberg
10th Gear
Can confirm..... annoying.
Old Aug 6, 2025 | 02:51 PM
Cough's Avatar
Cough
My Grand Highlander is the same - always 1 mph or 1 kph off.
Old Aug 7, 2025 | 06:44 AM
TxTom's Avatar
TxTom
My TX350 cruise control slows down a little when I go into a curve. Kinda annoying.
Old Aug 8, 2025 | 08:42 AM
Lumberg's Avatar
Lumberg
10th Gear
+1
You may also notice a 'curves ahead' icon that momentarily appears on the instrument cluster about the same time the car makes a speed/power adjustment in the curve.
You might see 'Deceleration Assist' and 'Dynamic Radar Cruise Control' to make 'Curve speed reduction' adjustments inside the Owners Manual [p.272, p.549 TX350]
I'm glad you mentioned this! I'll probably adjust mine the next time I remember.
Old Aug 8, 2025 | 08:55 AM
TxTom's Avatar
TxTom
Let us know if you can delete that slow down.
Old Aug 8, 2025 | 04:06 PM
Vlad6525's Avatar
Vlad6525
FWW I have a 2022 RX450h and most of the time it also cruises 1mph under set limit, but sometimes it "catches up"...
Old Aug 11, 2025 | 12:42 PM
Cough's Avatar
Cough
Good news. After I posted here last week my car was in the dealership for a number of things. When I picked it up, for some reason the cruise set speed and actual speed now match exactly. There must be some software update that they installed (even though I hadn't asked). Check it out next time your vehicle is in for service.
Old Aug 13, 2025 | 07:15 PM
AL13NV8D3R's Avatar
AL13NV8D3R
I was going to make a post about this too! I own a 2022 RX 350 Fsport and had it serviced for an airbag recall. Lexus gave me a 2025 Lexus TX 350 AWD as a loaner and I have this same problem. It is only showing me going 1 mph less than what I set it at even when going downhill. I took a picture of it too. Here it is. I have mixed feeling about this vehicle. I wonder what was wrong?
It stayed at 74 mph for the whole 45 minite trip on highway.
Old Aug 14, 2025 | 06:39 AM
mcomer's Avatar
mcomer
There is a Curve Speed Reduction setting with High/Low/Off choices.
Old Aug 21, 2025 | 03:42 PM
Lumberg's Avatar
Lumberg
10th Gear
Originally Posted by Lumberg
+1
Follow up - tested the 'Deceleration Assist' and the slowdown in the curves was not affected.
Interestingly, I noticed the cruise control commanded speed and actual vehicle speed was the same for a time much longer than I have ever noticed before. You might even say it acted "normal."
Coincidence??? Perhaps some others could provide a few more data points if they make a setting change?
After having no effect in the twisties, I turned it back on because Im not yet certain what others systems it may interact with; Auto braking, stability control, collision avoidance, distance following, etc, etc, ....? Who knows.......?
Settings >> Driving Assist >> Driver Support => Deceleration Assist
Still toying with the menu sticks to find the 'Curve speed reduction' option.
Just a little more homework to do.....
Fortran
NX - 1st Gen (2015-2021)
Apr 20, 2021 08:48 PM
tyue
RX - 4th Gen (2016-2022)
13
Nov 7, 2020 04:37 PM
MSterling
ES - 7th Gen (2019-2025)
Apr 12, 2019 07:23 PM
7schulz
20
Sep 21, 2011 06:25 PM
