Suspension Springs, shocks, coilovers, sways, braces, etc.
Spring Installation Pics or Instructions?
Old Jul 11, 2013 | 07:09 PM
Ultra150's Avatar
Ultra150
Default Spring Installation Pics or Instructions?
I have a 13' GS350 F-Sport and have rsr super down springs coming, but cannot find any DYI pics anywhere. Please help.
Thanks.
Old Jul 11, 2013 | 07:47 PM
Nexson's Avatar
Nexson
Me too! Well no springs yet, but I would like to see. Where in FL are you?
Old Jul 12, 2013 | 05:04 PM
Ultra150's Avatar
Ultra150
I'm in Miami.
Old Jul 12, 2013 | 05:09 PM
Stew4HD's Avatar
Stew4HD
From what I can gather, the front is a strut/spring combo, so you need to remove that assembly, compress the spring to remove it, compress the new spring and install.
The rear is much easier to get to on the car, just compress, remove and then compress new spring to install...
Need jack stands and a decent floor jack.
I have way over simplified it but you should be able to do it.
Old Jul 12, 2013 | 07:33 PM
Nexson's Avatar
Nexson
Originally Posted by Ultra150
I'm in Miami.
Cool, I am in Pines. Maybe we can find a shop, you can go first so mine comes out better lol
Old Jul 14, 2013 | 08:04 AM
Ultra150's Avatar
Ultra150
Thanks Stew4HD, I will more than likely attempt the job next Saturday.
Nexson, I'm pretty handy and have the tools needed for this job. Shops in S. FL are pretty expensive so will tackle this job myself, and some help from a buddy. I'll let you know how it comes out.
Old Jul 14, 2013 | 08:18 AM
Stew4HD's Avatar
Stew4HD
If you have the tools, I am sure you can. I wish I would have done it myself!
If you guys can, please document the project. I am sure that others will benefit from what you learn and do!
Old Jul 14, 2013 | 03:57 PM
Nexson's Avatar
Nexson
Send me a PM and I can drop by to help. I have some air tools if ya need, . Along with an arrangement of jacks/jack stands etc.
Old Jul 14, 2013 | 03:58 PM
Nexson's Avatar
Nexson
Also, What color is your car?
Old Sep 9, 2013 | 08:45 PM
elusive's Avatar
elusive
Any update on this? The fronts look straight forward. The rears I'm not sure about. It looks like I have to compress the rear spring while its on the car and not touch anything else. Any info would be great.
Old Feb 10, 2014 | 07:51 PM
14GS350F's Avatar
14GS350F
I found it easier to unload the factory spring by loosening the outside control arm, and installing the spring by loosening just the inside of control arm
Old Feb 15, 2014 | 10:31 AM
Schmexus's Avatar
Schmexus
You can rent/borrow the spring compressor tools from Autozone for free. I've done it without them, but they make the job soooooo much easier.
Air gun+spring compressor=life saver.
Old Feb 18, 2014 | 07:25 AM
G-SharK's Avatar
G-SharK
Simple job if you have all the right tools. Air gun or electric gun (makes your job easier), floor jack, two jack stand or one if that's all you have. You will need an extra hand. The rear is simple. Remove the wheel and remove 3 bolts and the spring will pop out (***be careful to have a floor jack supporting the bottom of the springs before you remove the last bolt, otherwise the pressure of the springs will shoot to the ground. Front is a little more work but not hard, just takes more time because you have to compress the springs to get it out and compress the new springs to get it back on. Most shops will charge 6-10 hours of labor. I did mine in about 3 hours with the help of my brother. Another helping hand is need! Check out this coil over install for picks of what you should remove. The instructions are not exactly to the point but will help reference you during the install. https://www.clublexus.com/forums/sus...0-f-sport.html
Gohanburne
Suspension and Brakes
Jul 7, 2016 04:44 AM
3ISRC
Southwest
Jul 30, 2015 01:49 PM
blue99GS4
May 5, 2009 08:54 PM
LiqrSicc
RX - 1st Gen (1999-2003)
Jul 14, 2006 02:11 AM
EGainer
Aug 7, 2002 08:18 AM
