Suspension inquiry
Old Sep 30, 2022 | 11:09 PM
mtnfcntgs1's Avatar
mtnfcntgs1
10th Gear
Default Suspension inquiry
Heyyyy guys and gals!!!!! Havent posted anything in a good minute but biiiiiig favor!!!! I need part numbers i would imagine for the control arm bushings, hell all the bushings front back up down on a 2000 gs300 plat edition if that makes a difference....
Old Oct 1, 2022 | 11:50 AM
firelizard's Avatar
firelizard
The suspension arm bushings don't have part numbers. For OEM (or OEM equivalent), the entire arm needs replacing. Or press out the OEM bushing and press in aftermarket ones.
Old Oct 3, 2022 | 11:44 PM
mtnfcntgs1's Avatar
mtnfcntgs1
10th Gear
Exactly, I'm trying to find am bushings because I'm going to press them myself, got that info maybe?
Old Oct 4, 2022 | 11:44 AM
captainva's Avatar
captainva
TBH you're better off just replacing everything with mevotech when you factor time in. Also several arms you can find the bushing but not the ball joint so its not worth it.
Old Oct 4, 2022 | 11:54 PM
firelizard's Avatar
firelizard
I'm not aware of any OEM style rubber bushing kits. Replacing the arm is the normal way to fix a worn or damaged bushing or ball joint.
FIGS Engineering has a full polyurethane bushing kit by SuperPro. SerialNine also sells some bushings but they're on an indefinite backorder at the moment.
Old Oct 7, 2022 | 06:07 AM
mtnfcntgs1's Avatar
mtnfcntgs1
10th Gear
No matter what I'm trying to find singular bushing parts/pieces because I have a press, might as well utilize it....
Old Oct 7, 2022 | 11:44 AM
firelizard's Avatar
firelizard
That's a weird reason to spend probably the same amount of money, if not more, and a lot more time. But like I said, FIGS Engineering master bushing kit, go nuts. You're stuck with polyurethane options though.
Old Oct 8, 2022 | 05:27 AM
Scigheras's Avatar
Scigheras
Hardrace sells a lot of rubber and spherical replacement bushings for a huge variety of cars including this one
Old Oct 31, 2022 | 01:33 AM
mtnfcntgs1's Avatar
mtnfcntgs1
10th Gear
Default Update
I've ordered poly bushings from siberian bushings, familiar?
Sweeks2020
Suspension
Sep 13, 2021 11:57 AM
Viru
Mar 16, 2019 06:21 PM
lexus_tt
Aug 7, 2007 07:44 AM
bigL
Suspension and Brakes
19
Jan 26, 2007 08:20 PM
skpark70
Jul 13, 2006 09:25 AM
