Coilover s
Old Apr 5, 2020 | 10:43 PM
TwistedFan's Avatar
TwistedFan
Default Coilover s
So my car is a 2nd gen and has just now hit 300k miles. So it’s time for an update on the struts. I want to lower the car for a future body kit project. So best Coilover brands for this kinda car. And go
Old Apr 7, 2020 | 06:18 AM
TrueGS300's Avatar
TrueGS300
Best for the VIP look and lowering with kits etc. is an airbag suspension. But it's more costly. Definitely the most baller depending on what you're after. As far as "best" coilovers available, what are you looking to spend? There are high end brands and very cheap ones. BC makes a great product, Tein makes anything from all out race to more mild street mannered. I personally am running the Tein street basis z set. Cheapest and lowest functionally available, but great for just lowering and street driving. Depends on what you want out of your coilovers. Do you need adjustable dampening etc.?
Old May 7, 2020 | 11:38 PM
StarBoy's Avatar
StarBoy
Would you recommend the Teins or the Bc coil set for quality?
Old May 8, 2020 | 06:51 AM
TrueGS300's Avatar
TrueGS300
I've never ran BC and have had two cars now with Tein coilovers and one with just Tein springs. There's nothing negative I can say about any product of theirs I've owned. I haven't developed any leaks and the ride is good. But I haven't actually had them on this car that long. And the car has sat most of that time with engine/trans modifications going on. I don't think you can beat the quality of Tein, even in their cheaper lineup. They are only cheaper because they have less functions, not because they are a junk product. So if you only need basics like me, I wouldn't shy away from a set. I'll never be on a track or anything with this car. The way they designed the basis z set is a perfectly matched spring and shock ideal for most driving conditions. I wouldn't want it stiffer or softer. Good all rounder at all times.
Old May 8, 2020 | 06:40 PM
FlashWhyte's Avatar
FlashWhyte
Will jump in on this if that's ok - save posting a new thread for essentially same thing!
I'm hearing a lot of good things about BC coilovers...
Though I haven't managed to figure out what the difference in their series V1 to BR is in terms of what they offer?
Does anyone know in lay terms?
Old May 8, 2020 | 07:54 PM
TrueGS300's Avatar
TrueGS300
This is a discussion on those I found, might answer some of your questions http://www.lancermotoringclub.com/sh...mp-BR-coilover
Old May 8, 2020 | 10:53 PM
FlashWhyte's Avatar
FlashWhyte
Ah right on, that basically clears up all questions I had! Cheers mate
Old May 9, 2020 | 04:02 PM
EuroWill's Avatar
EuroWill
A little more in for on Tein. They are probably the best bang for the buck coilovers made. I currently have the Tein Flex Z, plus EDFC and Motors (which are not installed), but am about to sell my setup because I have outgrown them. How have I outgrown them you ask? My car is a track/show car and I need a stiffer setup. The Flex Z's are great, but I have have too much dive, since installing my front and rear BBK.
I will probably buy either Aragosta or HPI/DG5.
Will
brucelee1
GS - 1st Gen (1993-1997)
Jul 19, 2016 08:15 PM
masco
RX - 1st Gen (1999-2003)
Aug 20, 2014 04:40 PM
buttnekkid
Jun 25, 2006 12:15 AM
loonyrobert3
32
Dec 8, 2002 07:55 AM
