front brake judder
Old 08-15-12, 08:26 AM
motorscape
motorscape's Avatar
Default front brake judder
Well I'm trying to sort the Lexus out for our prauge trip and I'm getting a lot of judder when braking
So what I've done is open all the suspension bolts and let everything hang free
I've found the bottom ball joints very floppy so replaced them also the track rod ends not worn much but cheap enough to replace,
Antiroll bar links worn and antiroll bar bushes worn and replaced
Looking at the bottom arm where the strut bolts to well I'm not sure how much play is allowed in them, they move side to side when you grip the end and when bolted up moved with a crow bar
The bottom tension arms or control arms again move side to side and I can see a little bit of rubber cracking in them, am I able to replace the bush or do I need the whole tension arm if so where from
It's important to remember that u have undone all the bolts holding the suspension together the only bolts left in are the ones going through the bushes difficult to fi.d play when everything is bolted together
Has anyone else done this and did it cure the brake juddering
Thanks
Old 08-15-12, 11:07 AM
cobalt91
cobalt91's Avatar
Brake judder or vibration usually mean a warped brake rotor. Bushings can be found on ebay if I remember correctly
Old 08-15-12, 11:45 AM
motorscape
motorscape's Avatar
I've looked on eBay but I can't see any at all do you know the correct name I'm looking for?
Old 08-15-12, 12:51 PM
RA40
Super Moderator
RA40's Avatar
The LS's are pretty sensitive to out of spec issues and vibrations show up quickly. Unbalanced tire/wheel, warped rotors, etc. You mention this shows up while braking so it is likely a warped rotor.
Take a dial gauge and spin the rotor to check for rotor runout. If that is ok, then I would suspect that there is pulsating being cause by the braking forces and it is related to a worn bushing. If the caster bushing has not been changed, it is a suspect. You've already replaced several other parts so knowing which one may not be easy at this point. Since the car will need an alignment after all this, I'd do the caster bar bushings if these have not been done. LCA and UCA do wear but I'd see if your current round of fixes caught it before spending more money and time wrenching.
Old 08-15-12, 04:37 PM
motorscape
motorscape's Avatar
Sorry for sounding silly but here are the castor bars? Also lca ans uca thanks
Old 08-15-12, 06:48 PM
RA40
Super Moderator
RA40's Avatar
These are the front caster/strut bars from the 95+. They connect to the lower control arm where the shock assembly attaches.
Old 08-16-12, 04:30 AM
motorscape
motorscape's Avatar
They are exactly what I'm looking for I've looked at the bushes on the end and they seem cracked its these bushes I want to replace I can't find them on eBay I'd prefere to replace the bushes if possible but if I'm stuck then it will have to be the whole arm, I'm getting no luck here in the UK could someone point me in the right direction please Lexus ls400 1995 ucf20. Thanks
Old 08-16-12, 10:40 AM
Lavrishevo
Lavrishevo's Avatar
Check out below. Pure Drifter has had experience with the aftermarket strut rod / bar bushings and says they are total crap. I would heed his advice and stick to OEM. Especially, for the front. Unfortunately, you can't buy just an the OEM strut rod / bar bushing. Cheapest I have found them in the States is $105.00 for the whole bar. I need to replace mine as well.
http://www.partsgeek.com/7n71mjp-lex...+W0133-1620052
http://www.armstrongdistributors.com/lexus.html
http://stores.autowearhouse.biz/-str...category=Lexus
https://www.clublexus.com/forums/ls4...-bushings.html
Old 08-16-12, 04:34 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
actually you can buy just the rubber bushing from Lexus, they are part no. 4867440051 and usually go for ~$35-40/each. you need 2.
when installing, make sure you have them clocked right. more info here: https://www.clublexus.com/forums/7069812-post25.html
Old 08-16-12, 05:54 PM
Lavrishevo
Lavrishevo's Avatar
I'm totally confused. I thought they could not be purchased separately. Does the part number apply for the 99 - 00 model year?
Old 08-16-12, 05:56 PM
PureDrifter
BahHumBug
95-00. it's actually quite well documented here lol, they became available a couple years ago.
I just redid mine a few weeks back, from poly to OEM. Need to put the bare rods up for sale so someone else can use them lol.
Old 08-16-12, 06:08 PM
Lavrishevo
Lavrishevo's Avatar
I just went to Sewell and double checked. You are correct. It is right there in front of me. Maybe since it was labeled as front bar cushion that threw me off... LOL Well, I totally stand corrected! Thanks, PD, again...
4867440051
CUSHION, STRUT BAR
$36.92 Sewell Club Lexus Price.
mdpresco
12-25-22 05:40 PM
forsythia
14
06-14-18 10:58 PM
Swint
18
04-06-16 04:48 PM
Goofaroo
16
11-05-12 07:30 AM
dkls400
13
10-21-10 01:48 AM
Quick Reply: front brake judder
