SPC front ball joints
Old Mar 26, 2012 | 11:34 AM
clubfoot's Avatar
clubfoot
Originally Posted by Gville350
Nope, just a nut on a threaded portion of the ball joint. Use Loctite blue.
That split metal thingy going through the threaded portion of the ball joint above the nut IS a cotter pin!
Once you set the camber and torque the nut to spec (120ftlbs I think) you install the cotter through the castellated nut and hole in the threaded portion and bend the protruding split ends to prevent it from backing out.
Torquing the nut to spec is the most important thing!
Old Mar 29, 2012 | 09:04 PM
RCB's Avatar
RCB
I think they are talking about the nut on the other end
I'll be staying away from these. Hopefully Figs has a solution soon.
Old Mar 30, 2012 | 11:15 AM
clubfoot's Avatar
clubfoot
OK,..that nut also has a torque spec,...shouldn't budge once it's tight!
Old Apr 5, 2012 | 01:01 PM
wald.sc400's Avatar
wald.sc400
BANNED for ripping off other members
what are the torque specs for the castle nut and 2 side bolts??
Old Apr 6, 2012 | 10:26 AM
clubfoot's Avatar
clubfoot
Here you go:
http://www.spcalignment.net/instruct...30-INS_WEB.pdf
AshyAnklez
IS F (2008-2014)
24
May 5, 2016 11:36 AM
RyPeredo
Suspension and Brakes
Feb 24, 2016 06:03 PM
LEXOWINO
Oct 22, 2015 10:50 AM
akxx
Jul 11, 2007 09:27 AM
kubys
Mar 1, 2004 09:00 AM
