DIY - Rear Axle Carrier (Knuckle) Bushing Replacement
Old Oct 28, 2012 | 03:24 PM
  #196
vwynn's Avatar
vwynn
so i decided to do some work on my car and some checking.. is that correct?
Old Oct 28, 2012 | 11:38 PM
  #197
FIGS's Avatar
FIGS
The Maker
Originally Posted by vwynn
http://www.youtube.com/watch?v=Bj-F-AYnz0Q
yes,
Also you should ditch those so called RCA's in the rear and get some of the new lowering arms we just released . That way you do not add another element of flex in the suspension and you get back stock camber bolt adjustment..
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old Oct 29, 2012 | 07:55 AM
  #198
Blanco's Avatar
Blanco
Originally Posted by FIGS
yes,
I can haz front UCAs????
Old Oct 30, 2012 | 09:38 PM
  #199
FIGS's Avatar
FIGS
The Maker
We are still working to close on this. I know it seems like forever but I am going to really push it this week.. If I have to cust some new nes and send them to a few more people to tes tI will.
Mike
__________________
Old Nov 1, 2012 | 10:29 AM
  #200
sakataj's Avatar
sakataj
yes,
he wont need them mike......i dunno if he has said anything but he got T-boned the other day. (Vince has now killed 2 Gs's and we are officially not allowing him to get and kill another,lol)
We are still working to close on this. I know it seems like forever but I am going to really push it this week.. If I have to cust some new ones and send them to a few more people to test I will.
Mike
nice....you know i would love a set. im fixing to have to replace another front tire from camber wear
Old Nov 14, 2012 | 12:06 AM
  #201
SlowGS4's Avatar
SlowGS4
This is next on the list
Old Nov 14, 2012 | 07:14 AM
  #202
Blanco's Avatar
Blanco
I just had to replace one of the ball joints on one of my SPC ucas yesterday. That's money I could be putting towards the FIGS....
How much longer do we have to wait???
Old Dec 12, 2012 | 11:09 AM
  #203
lexusben's Avatar
lexusben
My car sounds like a broken mattress. I am guessing these bushings may be the culprit. At this point, does anybody have a link to where I can buy these from?
Old Dec 12, 2012 | 07:58 PM
  #204
FIGS's Avatar
FIGS
The Maker
http://shopfigs.com/v1/LEXUS,%20susp...product_id=129
__________________
Old Dec 12, 2012 | 10:24 PM
  #205
Blanco's Avatar
Blanco
So I had to replace my FIGS bushings with the NZ parts. After driving a week or two I got a popping sound from rear suspension. Turned out the Figs were binding. Love the parts but for some strange reason, in my application they didn't quite work out.
I still want a set of front upper control arms though!!!!!
Old Dec 12, 2012 | 11:06 PM
  #206
FIGS's Avatar
FIGS
The Maker
Binding? What was the symptom? We might need to relax the tolerance.
__________________
Old Dec 13, 2012 | 07:03 AM
  #207
sakataj's Avatar
sakataj
dont tell me that micheal since i sold the ebay ones after acquiring my FIGS ones.....binding on what btw?
Old Dec 13, 2012 | 01:45 PM
  #208
lexusben's Avatar
lexusben
Here are a few videos of the sounds I am getting. It's not pretty. I can put about 20lbs of force on the rear of the car and get this sound. This means that on every tiny imperfection in the road my car is squeaking. I also have to hear it every time I get in and out of my car.
http://tinypic.com/player.php?v=w6pe38&s=6
http://tinypic.com/r/av2c5u/6
Old Dec 13, 2012 | 02:55 PM
  #209
Blanco's Avatar
Blanco
I'd get a pop sound every time the rear suspension would articulate up and down over anything other than the slightest road imperfections, regardless of speed. It was relatively subtle, but you could hear it if the stereo was down, and the bump wasn't too big. Parking lots were where it was most noticeable.
My wife even noticed it. It came from both sides, but the driver side was louder. My mechanic pointed it out to me when I was have some other suspension work done. I told him to look for a pop. I didn't tell him what I thought it might be, although I did mention that I had replaced the knuckle bushings.
I wanted them to be ok, but he showed me what was going on. He had a bar going through the bushing and he would grab one end and move the bar in order to articulate the joint. It would move freely for the most part, but it'd bind at a certain angle, and the bar would stop moving freely. He'd then have to apply significantly more pressure to the bar to get the joint to move beyond the binding point, once past that point, it'd move freely again until coming back down, or across that point going the other direction.
So I had him replace them with some of the NZ bushings. Wala!! no more popping.
Mike I still have the bushings if you want them. My mechanic was a bit rough getting them back out, but I can't use them.
I don't know squat about suspension systems, but I was thinking maybe the inside diameter of the knuckle was a bit smaller than expected. I did have a HELL of a time getting the old bushings out, and putting the FIGS in when I did it myself.
I still like FIGS parts, I really want the upper control arms. It's just a bummer that I had to buy two sets of bushings to get my fix on.
Old Dec 14, 2012 | 12:47 PM
  #210
FIGS's Avatar
FIGS
The Maker
It sounds like the bearing may have gotten brinnelled during installation causing a flat spot. I would love to get these back to do a failure analysis. Please contact me via phone or email.
Mike
__________________
