View Poll Results: what to you want?
I want endlinks
19
38.78%
I want tie rod ends.
30
61.22%
Voters: 49. You may not vote on this poll
FIGS Adjustable tie rod ends...renderings
Old May 14, 2011 | 01:28 PM
  #181
marshun's Avatar
marshun
looks good!
Old May 14, 2011 | 07:30 PM
  #182
ZippyGuy's Avatar
ZippyGuy
Hey Mike - are the endlinks going into production?
Old May 14, 2011 | 11:36 PM
  #183
FIGS's Avatar
FIGS
The Maker
yeah I will release the endlinks once we get confirmation that there are no noise issues.
All parts are in stock and ready to go.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old May 15, 2011 | 12:08 AM
  #184
sam430's Avatar
sam430
Well, I eliminated all my noise... I had my suspension on soft and allowed too much travel.
Old May 15, 2011 | 12:09 AM
  #185
sam430's Avatar
sam430
I need them soon as I will start to adjust my suspension to go lower and also do fender mods. I would like to get them installed
Old May 15, 2011 | 09:42 AM
  #186
FIGS's Avatar
FIGS
The Maker
Originally Posted by sam430
what would it take to get the front lower control arm done? It looks complicated and made of some thick solid steel. This would correct the camber issue and help with adjusting not so perfect wheel (poking/sinking) when using it with the custom UCA.
it won't be too hard actually, just need to get back to designing. I have to make a few sets of caster arms ofr some high HP cars this week, so I should get that part done at least.
The front RCA will start at $150.
__________________
Old May 15, 2011 | 10:38 AM
  #187
sam430's Avatar
sam430
great news.... i need to tame some very aggressive wheels. a shorter lca and uca will help to not have to do aggresive fender mod.
Old May 17, 2011 | 04:49 AM
  #188
eyecon7's Avatar
eyecon7
So if there is a shorter LCA, camber would be more positive correct?, i just bought SPC UCA, still need to get Figs Toe rods(F/B) and RCA's
Old May 17, 2011 | 10:15 AM
  #189
sam430's Avatar
sam430
I would assume it's the case. I may end up drilling and smoothing rough surfaces, if possible, the section to allow more positive camber adjustment. I'll have to look at it. Safety first.
edit: easier said than done... I don't know what is affected by making the lca shorter or cutting the camber section to allow more positive will affect the other arm (s arm or whatever it is)
Old May 17, 2011 | 10:33 AM
  #190
sakataj's Avatar
sakataj
WELL confirmation mike, i have gotten my noise issue resolved. part of the reason i never addressed it in detail on here was i didnt want anyone to think it was your product. it def wasnt.....got it resolved now.....sadly the alignment guy, a friend who has a rack i had it up on, and myself all missed it...took it back to the guy who originally installed it and he was stumped, then we noticed that the sway bar (where it screws into your endlinks) were loose. tightened them up and have been clunk free since last thurs now just need to get my alignment figured out, alignment shop is saying my power steering rack is coming loose, im assuming he means its flexing but i have the daizen bushings on there also and they fairly new so i dunno. im gonna have to get under the car with him and have him show me BUT all noises are gone
you were having noise also?
Old May 17, 2011 | 11:36 AM
  #191
StarkoS14's Avatar
StarkoS14
steering rack travel? inner tie rods would clunk when bad too... just like outer/lower/upper ball joints...
Old May 17, 2011 | 01:42 PM
  #192
sam430's Avatar
sam430
noise was mainly due to install error.
Old May 17, 2011 | 02:18 PM
  #193
sakataj's Avatar
sakataj
thats what he says.....he is saying the steering rack is pulling out forcing the car out of alignment again. i dunno the truth yet.....i have no front clunk noise.....i do have sporadic one coming from the rear though
Old May 17, 2011 | 03:47 PM
  #194
StarkoS14's Avatar
StarkoS14
yeah, thats exactly what my car is doing... I'm just replacing both inners and calling it a day
Old May 20, 2011 | 01:38 PM
  #195
sakataj's Avatar
sakataj
and thats supposed to fix a power steering flex?im assuming,but i dont even know if you talking to me anyways as you dont EVER quote......
