View Poll Results: what to you want?
I want endlinks
19
38.78%
I want tie rod ends.
30
61.22%
Voters: 49. You may not vote on this poll
FIGS Adjustable tie rod ends...renderings
tie rod ends.
I do want end links too, but considering most of us probably won't track hardcore our cars, can't why not just a plate that offsets the mounting point between the end links and sway bar...?
if you do make that, could you please make a flat spot in the middle so we can take a wrench to wiggle the arm when installing? looks like you have a 98-00 caster arm, look at the 01-05 caster arm for reference.
A plate will see too much moment I think and fatigue over time. Besides the stock endlinks up front are joined with the stud. so I am not sure where the plate would end up?
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Mike
__________________
^something like that.
night pager makes them...which seems sufficient enough for just road use? but I don't know jack about engineering either.
http://www.night-pager.com/cn30/cn34/pg399.html
man..i just want to remove bumpsteer..all these complicated stuff is making me confused, but im down for whatever to make my suspension close to stock wit the exception for minimal camber for the rear rims ill be running...keep us posted FIGS ENG.
__________________
I'll make it simple for you, when you go low, your steering geo changes. whether its just a suspension drop, or when your car dips in a turn due to weight. you, "dial in" your suspension by aligning to compensate for the drop. bump steer happens when your tie rods and Lower control arms are no longer level and causes snappy steering. one thing I hate about my knuckles on my 240 now...
I have MEGA arms and toe links for the 2GS currently. I also have an RCA spacer that will work, I just need to remove more material off it and that has not been done yet.
__________________
no price yet, still waiting on a few things.
__________________
