Tein CS : Changing spring rate
Old Apr 24, 2006 | 11:51 AM
gau17's Avatar
gau17
Default Tein CS : Changing spring rate
I've had the Tein CS for about 3 weeks now and I was kinda missing the stiffness of my old Flex shocks. I love the quietness of the CS. I was wondering if anyon has tried to change out the spring rate to get a slight stiffer bounce. My problem is that I have lowered the sping seat to where I have about 5 threads left. And as you guys know when you lowere the spring it decompresses it. I was thinking of changing out my front spings and go 2KG higher.
Old Apr 24, 2006 | 01:29 PM
RMMGS4's Avatar
RMMGS4
Northern California Regional Officer
Increasing the spring rate is just going to bring you back closer to the Tein Flex you had originally. The CS shocks were valved for the lower spring rate. Putting a stiffer spring is going to leave you on the under damped side, making the car bouncy.
Did you try adjusting the CS to almost full stiff in the damping? This would be the best compensation you can do.
Sounds like you like the Flex better. Put em back on if you really like em.
I know what you mean about the CS being a tad soft on the spring rate. The new improved CS models coming out are rumored to have a litte more spring rate than before.
You might just wanna wait and see. The new models are released, but no clue when they will offer them for our model of car .
Old Apr 24, 2006 | 01:32 PM
gau17's Avatar
gau17
Thanks for the info. I'll try the max setting to see how the ride is.
Old Apr 24, 2006 | 02:44 PM
cliffud's Avatar
cliffud
Former Vendor
I feel the same way and I miss my bilstein/eibach setup. BUT... this is a luxury car we're talking about - not some race car. With that in mind, I won't be changing back unless I get a gs4 or something.
Old Apr 24, 2006 | 03:26 PM
punch10's Avatar
punch10
If you want to change out springs, call tein and ask to what spring rate the CS is valved for...
Old Apr 24, 2006 | 04:48 PM
FutureGS400's Avatar
FutureGS400
Don't know what other suspension mods you have, but if you decide to do stiffer sways, chassis braces etc. then you will firm up the suspension somewhat. Not to the level of the Flex, but with the dampers firmed up and the body lean controlled better, you might find you like it! One of the advantages of coilovers is that the damper and spring are carefully matched and if you change the spring, the damping may be insufficient as already mentioned.
Mine have 45k on them and still going strong
Old Apr 24, 2006 | 06:09 PM
HKGS300's Avatar
HKGS300
I have shock dyno'd the CS shocks and these are relatively soft. By replacing your springs for slightly stiffer ones, you can make the ride a little stiffer, but not too much (since the CS were designed for these spring rates). The Flex shocks are much stiffer (100% stiffer ) than the CS according the Tein information on the Japan website.
Old Apr 26, 2006 | 10:53 AM
FutureGS400
Arrow
After looking at the Tein website and the CS instructions, it seems as though they might offer optional springs for them. Check it out here: http://www.tein.com/ti/inst/rt76u.pdf
Old Apr 26, 2006 | 11:00 AM
gau17's Avatar
gau17
Yes you can get high spring rate springs from Tein. $100.00/pair per TEIN Tech.
Old Apr 26, 2006 | 11:21 AM
cliffud's Avatar
cliffud
Former Vendor
Good find Mike! I wonder which spring rates mimic the Eibach springs the most?
Here's the list of springs they offer. Scroll down to the Straight Type $50.00 in bold...http://www.tein.com/stsp.html
JDMsedan
Suspension and Brakes
Jun 17, 2007 12:22 PM
gshb
Feb 14, 2007 01:09 PM
lexforlife
21
Jun 4, 2006 09:49 PM
vicestan
Nov 5, 2005 03:20 AM
