Tein cs
Old Nov 3, 2005 | 08:56 PM
vicestan's Avatar
vicestan
Default Tein cs
Hey guys, would tein cs from a lexus IS fit on the gs?
Old Nov 3, 2005 | 10:43 PM
rominl's Avatar
rominl
exclusive matchup
they have different spring rates though (probably damepning too)
Old Nov 3, 2005 | 10:54 PM
vicestan's Avatar
vicestan
Hmmm but would they fit though? The stiffness is adjustable so that can be tweaked no?
Old Nov 3, 2005 | 11:10 PM
rominl's Avatar
rominl
exclusive matchup
i am thinking very hard, i think they look very similar, i had the tein coilover for my IS before and they looked about teh same
however, the adjustment won't help. the spring rate you can't "adjust", and i highly suspect the car will drive right, since the two cars are pretty different
Old Nov 4, 2005 | 06:10 PM
chuckb's Avatar
chuckb
LEXUS IS300
part # JCE10 00+ CS Info DSY20-RUSS3
$1500.00
spring rates10/559SL100-01200 8/448SM080-01250
LEXUS GS300/400/430
part # JZS160L 98-05 CS DST76-RUSS3
$1500.00 9/504SM090-01250 8/448SK080-01300 spring rates
http://www.tein.com/products.html
Old Nov 4, 2005 | 07:29 PM
vicestan's Avatar
vicestan
So the spring rates are really not that different.
Old Nov 4, 2005 | 08:23 PM
Neo's Avatar
Neo
The One
They are close but it does make a difference. Also, the shocks have different part numbers. Although that does not guarantee that they are different, I am not sure I'd take the chance unless I know for sure. I have a feeling it is different because the cars are different sizes and weight. The coilovers have to account for that.
The length is also potentially different. I don't have an IS so I cannot be sure but does Lexus use the same parts for the IS and GS? With all the "ifs", I personally would not take the chance.
Old Nov 4, 2005 | 08:46 PM
chuckb's Avatar
chuckb
ya, the shocks probably have different valving inside for different car weights and spring rates
Old Nov 4, 2005 | 09:58 PM
Bad idea I'd guess - I'd imagine the whole units are a different size than the GS ones, but best for you to call Tein.
Old Nov 5, 2005 | 03:18 AM
HKGS300's Avatar
HKGS300
The length of the shocks are different, the GS ones are much longer, so if you install the IS ones on the GS, expect that your GS will be too low, ... so you will likely damage your suspension parts and bottom.
Front topmount of the GS is different to the IS, so you need to get GS replacements.
Since the GS is much heavier than the IS, expect that you need to replace the springs and shocks may not be strong enough to provide a safe / good handling when you are pushing your GS ...
Old Nov 5, 2005 | 03:20 AM
HKGS300's Avatar
HKGS300
Originally Posted by chuckb
LEXUS IS300
$1500.00
LEXUS GS300/400/430
Note ...
The GS springs are longer than the IS springs ... spring rates are only one of the many characteristics of a spring ...
Unqlyrwstl
GS - 1st Gen (1993-1997)
14
May 22, 2014 12:27 PM
JDMsedan
Suspension and Brakes
Jun 17, 2007 12:22 PM
gshb
Feb 14, 2007 01:09 PM
gau17
Apr 26, 2006 11:21 AM
krazydave
Aug 11, 2005 09:40 AM
