DIY Changing Brake Pad Tutorial
Old Apr 30, 2005 | 09:39 AM
GS300Rich's Avatar
GS300Rich
Originally Posted by T.L.W.
hell yeah ..its a ton easier
2 10mm hex bolts
and the caliper comes off ....remove the pads and replace
done
Thanks for the reply. So the rear pads you have to remove the caliper in order to remove the pads?
Old May 1, 2005 | 06:22 AM
russ29's Avatar
russ29
Default removing the rotors
I saw going to replace pads and rotors but I could not get the rotors to budge. Pads are a breeze. Any advise on removing stuck rotors?
Old May 1, 2005 | 04:29 PM
TLW's Avatar
TLW
the rear rotors have threaded holes to put bolts in and push the rotor off
wd-40 helps also
Old May 1, 2005 | 05:49 PM
russ29's Avatar
russ29
Default stuck front rotors
Any hints on removing stuck front rotors? I pounded and pounded (not metal to metal) and I can't them to budge. Thx
Old May 2, 2005 | 06:33 AM
slickgt1's Avatar
slickgt1
Hit harder. Same thing was happening to my friend. He was hitting it for 15 min before I showed up. I put a 2x4 against the rotor, and hit it insanely hard with a much biger hammer. Came right off.
Old May 19, 2005 | 02:58 PM
elclassico's Avatar
elclassico
Default pad noise
is this because i used no grease? what exactly am i supposed to grease on the front and rear brakes, or should i wait>? im getting a noise like to washers vibrating together, like a jingle sort of? please help. also herd of lubing the rear pins? with caliper grease? and between the shims and the calipers?
10lexISR6
RC - 1st Gen (2015-present)
Jun 25, 2018 08:46 PM
LexGX460
GX - 2nd Gen (2010-2023)
Aug 17, 2015 12:38 PM
islexusred
Oct 10, 2012 09:07 AM
swat1727
Suspension and Brakes
Aug 6, 2008 05:00 PM
/Aerostar\
Wheels, Tires & Brakes Forum
14
Oct 22, 2004 03:51 PM
