1995 LS400 cranks but won't start.
Old 03-17-18, 03:47 PM
sedgewick
sedgewick's Avatar
Default 1995 LS400 cranks but won't start.
1995 LS400. Parked it for a couple weeks and now turns over fine but will not fire. Sprayed starter fluid in air intake and briefly achieved ignition. The check engine light does not light up when key is inserted and turned. Thank you, Tom S
Old 03-17-18, 05:02 PM
sha4000
sha4000's Avatar
How many miles? Is the battery in good working order?
Old 03-18-18, 05:47 AM
python
python's Avatar
ecm........
Old 03-18-18, 07:02 AM
qewani1
qewani1's Avatar
check battry voltage first, if fine then it could be the starter and spark plugs
Old 03-18-18, 09:45 AM
sedgewick
sedgewick's Avatar
Default Additional info
Batteries good and spark is present. Got fire with starter fluid introduction. Does the fact that the check engine light fails to illuminate at all, even upon initial key turn lend itself to ecm failure? Are problems like that a spontaneous event ae. turning off and setting will be enough to initiate. Car has 115,000 miles and ran fine until short layoff.
Thank you all for your responses,
TS
Old 03-18-18, 08:17 PM
Amskeptic
Amskeptic's Avatar
Old school diagnostics sez . . . if you briefly achieved a little running, you can rule out the ignition system and focus on the fuel system.
Check for cranking fuel pressure, if no, pump/circuit. If yes, injector circuits including cam position sensors, AFM, etc.
Colin
sedgewick (03-19-18)
Old 03-20-18, 04:23 PM
timmy0tool
timmy0tool's Avatar
I say fuel pump. certainly fuel related, as amskeptic said what you did would confirm this.
jbattiest
11-16-18 09:19 PM
LANcr3w
50
02-03-13 02:46 PM
rustylexus
02-21-09 10:04 PM
wayne86
12-28-07 10:50 PM
avalon42
12-21-07 03:38 AM
Quick Reply: 1995 LS400 cranks but won't start.
