High idle in park or N
Hey guys. So my 91 celsior is idling at 800 in N and P and at 500 when in drive. When I go from P or N to drive it does clunk a bit as it shifts into gear.
While driving the shifts from 1-4th are very smooth, almost unnoticeable at gentle cruising. It downshifts great too.
Your idle speed is normal - I read a spec and did some testing on my 1991 last year, which idles around 600-800 RPM when warmed up and/or in warm weather.
When you put the car into gear, the RPMs should go down naturally, and a slight clunking noise when going into gear is also normal. You can inspect your engine and transmission mounts to double check, but I doubt they are bad since you mentioned shifting when in gear is smooth.
CamelKool (10-10-20)
the hard shifts into gear usually equate to a few things other than high idle (which you don't have unless the engine is cold). I would first check your engine and transmission mounts. that's usually toast at 100k or so. then check your guibo bushing on the drive shaft. search more on that one.
