View Poll Results: How is your air suspension?
My car has under 100.000 miles and the AS is fine
19
54.29%
My car has under 100.000 miles and the AS has been replaced
8.57%
My car has over 100.000 miles and the AS is fine
11.43%
My car has the AS replaced over 100.000 miles
0%
My car has no air suspension
25.71%
Voters: 35. You may not vote on this poll
Has your air suspension failed?
Old 07-21-17, 12:41 PM
Higgie
Higgie's Avatar
Default Has your air suspension failed?
Just curious, everybody is talking about failing air suspension. Most of you don't want it because of the costs if it fails.
Did your air suspension fail?
My car has 125.000 miles on it and the original air suspension is working fine (including the ASC680)
Old 07-21-17, 02:39 PM
213374U
213374U's Avatar
Currently at 91K (2010 L AWD) on the stock air struts and just installed an ASC680.
Definitely curious to see the outcome of this poll
Old 07-21-17, 04:14 PM
1WILLY1
1WILLY1's Avatar
I'm at about 45 000 miles and mine is fine except for the fact that it changes the ride height all the time
Old 07-21-17, 04:34 PM
FatherTo1
FatherTo1's Avatar
What is the ASC680? Is that the air compressor? It never occurred to me that air struts would be good but problems would arise with the compressor component. Makes sense now though. How much is it to replace an ASC680? Also, what are the symptoms to look for? Thank you.
Old 07-21-17, 07:51 PM
213374U
213374U's Avatar
Air suspension controller to manually adjust the height of the vehicle....
https://www.clublexus.com/forums/ls-...fo-thread.html
Front space at work was open after lunch today so I put her in LOW mode :P
I won't do this often, but hadn't done it yet and wanted to see just how low it goes. Not going to give SUPER LOW a try.
Here she is lowered just a touch for daily duties, 27.5" (ground to fender through the center) all the way around
Old 07-21-17, 08:00 PM
FatherTo1
FatherTo1's Avatar
Oh, I see now, it's a separate aftermarket device. I thought it was an OEM part to worry about.
I almost never saw 460s in our area but after purchasing ours I now noticed 3-4 07-12 models around the neighborhood. I pass by a 10-12 every morning as it's parked outside on someone's driveway. It's a silver L and a real looker.
Old 07-21-17, 08:17 PM
fwhomeboy
fwhomeboy's Avatar
Mine has Air and it's working just fine. 2007 460L and, It's the best looking Mercury Metallic Lexus, this side of California. I would post a picture but, I have so much respect for all of the people here, I don't wanna **** off the Masses !!!
Old 07-24-17, 01:27 PM
riknchar
riknchar's Avatar
The rear air ride shocks were changed at ~ 47K miles and the front air ride shocks were changed at ~58K miles on my 2008 LS600hL. No problems since then, and I now have 83K miles on the car...
Old 07-24-17, 05:35 PM
Cubbylex
Cubbylex's Avatar
My 2010 L has just turned 64k and just replaced the two rear air shocks last week. Lexus tech said front are still good.
Cubby
Old 07-25-17, 12:09 AM
MobbinVIP
MobbinVIP's Avatar
07 LS460L
120k & still going strong
but who knows what will happen when I install the lowering links & data controller
Old 07-25-17, 05:25 AM
sapstar66
sapstar66's Avatar
Have been complaining about the thumping of the control arms in front for a bit (car had around 60000 miles at the time). I think the service manager at my dealer was fed up of hearing me complaint every time and decided to change everything except for the height sensors. Don't know for sure if the suspension was ok or not, but who's gonna ask?...
After that, height issues in the front... so here I go *****ing again... they replace all but the faulty one (which was the leg that was up all the time). Finally changed the culprit last spring...
Old 07-25-17, 07:02 AM
rstewart
rstewart's Avatar
Default Air Suspension
I have 52,000 on my LS, no problems of any kind.
Old 07-25-17, 01:38 PM
213374U
213374U's Avatar
Cubby
Did you take it in for suspension issues or was it a case of the tech telling you "they're on the way out and should be replaced" and you decided to do it?
Old 07-29-17, 09:58 PM
mckellyb
mckellyb's Avatar
I have 105K on mine, all is well, and I use the "Height High" button at least twice a day.
The extra 3/4" makes a world of difference getting in/out. I have broken too many bones in my life.
BNR34
11-21-23 07:35 PM
ReeM
Suspension and Brakes
11-22-16 07:10 PM
ImolaS54
12-27-09 05:35 AM
BNR34
13
01-28-08 01:51 PM
DJ SprinklesNJO
RX - 1st Gen (1999-2003)
07-02-02 09:50 PM
Quick Reply: Has your air suspension failed?
