HID ballast cover
Old 06-20-17, 09:18 PM
Milonga
Milonga's Avatar
Default HID ballast cover
Hello fellow owners,
I was searching thru the forum and didn't find anything regarding what I am about to ask. I am going to be replacing my OEM ballast with some aftermarket ones but my question becomes, I want to remove the ballast from the headlight housing but I do not want to leave that hole there. Has anyone removed the OEM ballast and if so, what did you use to cover the space.
Thank you for your input and safe driving 🚘
Old 06-21-17, 07:08 AM
guzzy92fs
guzzy92fs's Avatar
I disarmed the ballast and used one of the sides to cover it, a hollow cover.
Old 06-21-17, 07:11 AM
Milonga
Milonga's Avatar
Originally Posted by guzzy92fs
I disarm the ballast and use one of the sides to cover it, a hollow cover.
Did not think of that, thank you!
Old 06-21-17, 08:30 PM
guzzy92fs
guzzy92fs's Avatar
Ur welcome, but why do you want to go out of factory ballasts?
Old 06-22-17, 07:41 AM
Milonga
Milonga's Avatar
Because I am going for LEDs, no need to have ballast siting there. I am going to find non working ones and use those and keep my working ones.
Old 06-23-17, 12:16 AM
guzzy92fs
guzzy92fs's Avatar
Oh, cool! Let us know which LED you go to, might be interested in the future.
Old 06-23-17, 04:32 PM
Milonga
Milonga's Avatar
Thumbs up
Will do so
Old 06-25-17, 11:33 PM
Vooduguru
Vooduguru's Avatar
following.
Old 07-17-17, 09:45 PM
guzzy92fs
guzzy92fs's Avatar
Hey Milonga, a buddy of mine installed LEDs to his GS using the SNGL Super Bright LED, give it a check. He used the ballast cover, drilled a hole and put a rubber grommet then passed the cables through.
Something like this:
These are the ones:
SNGL Super Bright LED Headlight Conversion Kit - Adjustable-Beam Bulbs - D2S ( D2R, D4S,D4R ) - 110w 12,400Lm - 6000K Bright White - 2 Yr Warranty
Amazon Amazon
Old 07-18-17, 05:56 AM
Milonga
Milonga's Avatar
These are the ones:
SNGL Super Bright LED Headlight Conversion Kit - Adjustable-Beam Bulbs - D2S ( D2R, D4S,D4R ) - 110w 12,400Lm - 6000K Bright White - 2 Yr Warranty https://www.amazon.com/dp/B01MG178DA..._s9yBzbHR377JJ
Awesome, I'm going to look into it. I haven't posted anything because I'm in school and don't have much time to work on it. Last thing I did was remove the HVAC drain plug because I developed the wet carpet syndrome. If you need help with that let me know, I'll be glad to help you out.
maxwebr
04-22-13 11:39 AM
ILOVEGIRLS
07-23-06 03:11 PM
ARISTO 161
03-16-05 03:45 PM
heyma
Lighting
08-26-03 11:27 PM
DrewGS4
07-18-02 06:42 AM
Quick Reply: HID ballast cover
