- How to Replace Your Wheel Hub Bearing
Step by step instructions for do-it-yourself repairs
Browse all: Tires and Wheels Guide
Front wheel bearing / hub replacement How to 04-06 LS430
Its fairly simple and straight forward If you can do brakes you can do this!!!
So first things first. You need to identify which wheel bearing is bad. I had some pretty worn out tires on my car and thought the loud vibration/rumble was because of that. After replacing my worn tires the rumble was still there. I couldnt think of what else would be causing such a noise considering my alignment was good. So I asked around and talked to a few mechanics and friends asking for thier input on what they thought it could be. Everyone suggested wheel bearings.
I had to determine which bearing was bad. I simply raised the car off the ground and and listened closely to each wheel as I spun it. Some recommend a sethescope. In my experience it is easier to hear when you get the wheel going faster rather than slow.
Listen for a grinding,friction, or just an un-smooth sound. Its a different sound than you rotors and pads touching alittle. (kinda hard to explain but you should hear a noticable differnce between a good and bad bearing.)
Ok on to the pictures and procedure, (sorry for the iphone pics)
First remove the wheel...
Next you will need to remove the caliper. It is only 2 bolts they are 19mm.
also unclip the "brake pad warning" sensor so you can get the caliper out of your way. Alot of guys set the caliper on a bucket or zip tie it up to the coil spring. Just get it out of your way and make sure it cant fall or drop so you dont damage your brake line or anything else for that matter.
Remove the rotor. You may need to gently knock it loose.
Now if you turn the wheel to the extreme left or right so you can see behind it you will see 4 bolts holding the whole hub assembly to the "spindle?" (Not sure the correct term or not.) They are 17mm Bolts. Remove them.
After removing them you will notice the hub assembly is stuck on there pretty well. Alot of times these seize on to the spindle and are quite difficult to remove. This is probally the most difficult and time consuming part.
Unclip the abs sensor.
What I found works well is a little mini sledge and a punch or a pry bar. Give the wheel hub some pretty good whacks all around it. Dont worry about damaging the hub its no good anymore anyway. Now you will need to work around the back of the spindle.
I couldnt get a good picture on the car but this is the area you will need to hit with the punch on the old wheel bearing.
Take your Punch and work it around hitting the edge of the wheel hub from the back of the spindle. You will probally need to do this a few times and quite hard.
Once the old hub and Brake dust shield has been removed you will need to get all the corrosion and dirt out of the hole in the spindle where the hub slides into. A wire brush works great for this.
Once the area is clean put the dust shield on the spindle and try to fit the hub into the spindle. Make sure it goes in fairly straight. If it is hard to get in you need to clean your spindle somemore. (The abs sensor points toward the rear of the vehicle)
Insert the bolts and tighten down in a diaganal pattern little by little similar to how you would mount a tire.
Make sure everything is tight plug your sensors back in, attach the rotor and reattach the caliper. Re-install the wheel.
Thats pretty much it! Hopefully this was helpful and clear. If you have any questions let me know or feel free to add any suggestions or comments! Thanks!
I loosend all four hub bolts, left them in and backed them off until there was about 1/8" or 3/16" space between the bolt and the knuckle. It took only one medium blow from a small 3lb hand sledge, on one of the bolt heads to dislodge the old hub... Using the sledge & punch method above was much more difficult.
The OP states that the ABS / Speed sensor connector points toward the rear of the vehicle. The is true only on the passenger side / right front. The left front points towards the left front. In other words, for both hubs, when facing the knuckle, the speed sensor connector is around 10 o'clock... (more like 10:30 if you want to get picky...)
Also, the torque specification for the two caliper bolts is 81 ft. lbs.. The torque spec for the four wheel hub bolts is 51 ft. lbs... Lexus warns not to overtighten the two caliper bolts since both the knuckle and caliper are made of aluminum. Lexus also recommends using two new caliper bolts any time the existing bolts are removed... (The torque spec for the rear caliper bolts is 58 ft. lbs.).
I must say that replacing these was very easy, as long as you have the right tools...
Jim
I didn't need to replace my front rotors, they spec'd out at 29.76mm. The acceptable range is 30.00mm to a minimum of 28.00mm. If you do need to buy them, they retail for $162.08 each but Sewell has them for $99.68 each for CL members...
I've been consistently happy with the service I've gotten from Sewell over the years. I check other sources before purchasing...
Just for future reference, the rear rotors thickness range is 16.0mm to a minimum of 14.5mm, the rear caliper bolts are to be torqued to 58 ft lbs (instead of 81 ft lbs in the front), and the four rear hub / bearings bolts are to be torqued to 48 ft lbs (opposed to 51 ft lbs for the front)....
Jim
