18 watt backup bulbs
Old Sep 3, 2014 | 12:56 AM
exraf's Avatar
exraf
Default 18 watt backup bulbs
Hi. I've removed the lens covers from the backup lights and although the light is now better - it's not great. The standard bulbs are 16 watt and I've found some 18 watt (same fitting) but haven't got the courage to try these as worried that the current draw/heat will be too much? Would be grateful if anyone could give me sone advice please.
Many thanks
Sorry - forgot to say that it's an RX 2007
Old Sep 3, 2014 | 05:56 AM
jfelbab's Avatar
jfelbab
Many thanks
18W is fine. I had good results with Sylvania Silverstar replacements from a local AutoZone. Bulbs can dim with age and use so just replacing them, if they are original, may give you more light. The Silverstar bulbs I used made the back-up camera display on my NAV much brighter.
Old Sep 3, 2014 | 08:12 AM
exraf's Avatar
exraf
Many thanks for that Jim - gives me the confidence to give it a go
Old Sep 3, 2014 | 11:03 AM
kickin8's Avatar
kickin8
2IS/2RX/4RX
or you can try this
https://www.clublexus.com/forums/rx-...leds-pics.html
Old Apr 24, 2021 | 08:13 AM
djeddieo's Avatar
djeddieo
Does anyone know how exactly to remove the lens covers?
Old Apr 29, 2021 | 06:04 PM
Badhobz's Avatar
Badhobz
https://www.canadiantire.ca/en/pdp/9...p.0202992.html
I just added these led bulbs above and they are super bright.
jessmessin
Lighting
Jan 4, 2022 04:00 AM
PeteGS300
Apr 19, 2013 07:26 PM
AWay
Lighting
Feb 16, 2004 10:56 PM
dasenzasian
Oct 22, 2001 09:45 AM
