GS 2006 450h hid adjustment
Old Oct 7, 2017 | 03:54 PM
icegoffy's Avatar
icegoffy
Default GS 2006 450h hid adjustment
Hi all, i couldn't find the gauges or bubble gauge that shows me the hid adjustment for low beam. All i found under the hood was 2 turning screw for adjustment, there's no bubble gauge anywhere. Could it be my was a 2006 model? and even when i adjust the screens it doesn't need a 12" long screwdriver to adjust like what some of the forum threads said, the turn screen is just by the side of the headlight assembly.
when i adjust it, i don't see the hid move anywhere, either left right or top down. Could it be my adjust screws have been broken?
Old Oct 8, 2017 | 07:15 AM
MX73's Avatar
MX73
You would have to remove the front plastic cover that covers the front end from left to right. The bubble is under the cover.
Old Oct 8, 2017 | 07:32 AM
Gs3500's Avatar
Gs3500
The long screw driver is required to adjust low beam up and down. There is a hole on the side of the engine bay to stick and guide ur tool through to the adjusting screw.
You also need to remove the lower plasteic engine cover from the top to reveal the bulbs.
Old Oct 9, 2017 | 12:58 AM
icegoffy's Avatar
icegoffy
Thanks.
Can you let me know where is the bubble gauge located in this picture?
Old Oct 9, 2017 | 06:34 AM
MX73's Avatar
MX73
Odd. It should be where that bolt is.
Old Oct 9, 2017 | 08:16 AM
Gs3500's Avatar
Gs3500
Clean up the clear plastic where that bolt is... do u see the bubbles? It’s right in there. There should be 1 for high and one for low beams.
Old Oct 9, 2017 | 08:17 AM
Gs3500's Avatar
Gs3500
Never mind what I just said. Try removing the bolt and see what’s underneath. Is your headlight stock?
Old Oct 11, 2017 | 08:33 PM
icegoffy's Avatar
icegoffy
not sure why, but that bolt is made of plastic not metal, i feel that if i force it it will break.
i wouldn't expect that i need to unscrew the bolt to see the bubble gauge. the funny thing is my manual also didn't have the section for headlight adjustment under the DIY section.
maybe the 2006 gs450h is abit different.
my headlight i can confirm is stock standard.
Old Oct 11, 2017 | 09:38 PM
MX73's Avatar
MX73
Maybe ask the dealer. I've seen a few pictures online that show the 450h having the bubble level. They also the special blueish lens compared to the regular GS.
Do you know if the headlamp was replaced with an aftermarket OEM style?
Old Oct 11, 2017 | 09:55 PM
MX73's Avatar
MX73
Could we get a shot of the headlights itself? Also are there any text on the lens itself. I think if it's true OEM, it would have a Koito stamp or another Japanese company stamp on there.
There is a brand called Spyder that sells aftermarket OEM style that has the bolt in place of the bubble. This is a link to the chrome, OEM style, https://www.carid.com/2006-lexus-gs-...-97691080.html. The one I'm posting up is the blackout version because it actually shows the top of the headlight housing but from the same company.
Old Oct 12, 2017 | 09:27 PM
icegoffy's Avatar
icegoffy
interesting, i took a pic from the outside of the headlight, didn't see any jap stamp
i see one of the same 2006 model here in this car advert, it doesn't look like its a bluish tint:
https://carsales.pxcrush.net/carsales/car/private/cp5329865803291131850.jpg?pxc_method=fit&pxc_size=1197%2c798
but the 2008 model have a bluish tint:
https://carsales.pxcrush.net/carsale...ize=1197%2c798
Old Oct 14, 2017 | 07:24 AM
MX73's Avatar
MX73
Here you go. OEM is made by Koito. Marking is towards the bottom left/right of the turn signal.
Old Oct 26, 2017 | 04:12 AM
icegoffy's Avatar
icegoffy
do you know if no bubble available how do i adjust the hid?
Old Oct 26, 2017 | 06:38 AM
MX73's Avatar
MX73
You would have to do it the old fashion way. You'll need a level road, a wall, masking tape an about 25 feet of straight road.
https://shop.advanceautoparts.com/r/...ust-headlights
Jacket
GX - 2nd Gen (2010-2023)
122
Feb 22, 2023 02:06 PM
lexus-is2
Dec 27, 2017 07:28 PM
aTeAse
Oct 30, 2013 11:47 AM
JH48
Mar 18, 2011 12:58 AM
nioks
Feb 26, 2008 12:55 PM
