Locks/fob not working
Hey, I have recently discovered the FOB will unlock the car but no longer locks the doors, rolls back the sunroof and I thought it was supposed to do remote start but never have gotten that to work…. Any thoughts???
Sorry .. was talking about the SC430 -it unlocks the car but does not lock it nor auto start or any of the other functions. It did fine before taking into the shop where they disconnected the battery …. No idea why it is not working any longer
FOB problem mostly causes by weak battery. Sometimes heat can cause it not to work properly. Don’t know about remote start.
You must have some aftermarket device. Our Key/FOB never opened the roof or auto started the car.
Did the Convertible top lower from the FOB also?
The factory FOB has a problem with sunlight and heat effecting the remote range. I also think heat effects the Lock Actuator Motor.
If you feel the system is working normally and the lock is just not working, you can google "clublexus.com sc430 lock actuator"
Great stuff all. I do not have a aftermarket that I am aware of, I purchased used and only know of the sunroof as I accidentally did it once After just getting windows tinted I hit something on the fob and windows started down, will check battery replacement and the heat. It has been really hot here in SC.
Paul
The only after market system which will remotely start the car that I know of is the LuxLink. Although, I don’t know that it will low or raise the top.
Few of us have LuxLink, they can offer more infos.
My remote stopped working and suspect it is the battery in the remote, it is a CR1616 fyi, ordered a few from mazon. Suggest you keep these handy. You will never know when they go out and it is a hassle if you do not have spare batteries. $5 for 6 pcs. Good investment. I think it makes sense to replace it every 2 or 3 years, regardless of use, good insurance you will not be grounded.
