Radio door motor
#31
Thank you for all your help
Hope you are doing well!
Ty so much for all the help!
I appreciate it!
I have been working on this issue
on and off since I purchased and picked up the car 3/11/22!
You and our clublexus community
has been so helpful and informative.
I was in other car clubs in the 80’s and the people were overall snobs and selfish. Paul and Daryl were very helpful also!!
Have a super Sunday and week.
Happy motoring!
Best,
Jeff aka Harleygirl
#32
I totally respect and appreciate those of you that do so much to repair your toys as inexpensively as possible. There was a time when I did the same. But for those of you who have a little less time and a little more money, I suggest the following strategy.
First, my failure point was not the motor. Nor was it the push button. It was the little toggle switch (red arrow pointing to that little brown thing). When the door travels forward (closes), the switch is pushed to the back (the green arrow shows the front gate). Conversely, when the door travels backwards (opens), the switch is pushed to the front. {Note: forward and backward is relative to the picture. If relating to the vehicle, it would be reversed -- door going forward is opening} That is how the door controller knows where your door is, thus which way to drive the motor. I drilled a 1/2" diameter hole in the plastic piece (below where the green arrow is) and I could see the broken piece. Someone mentioned a laser, or infrared, but I doubt that is the case since you'd need two to know which side of travel you are (open or closed). I could be wrong, but I think everyone has this same type of mechanical switch set-up.
The answer for me: order part 55406-24040. It is the entire radio door assembly sans the decorative cover. It comes with new clips and screws for the cover, so just reuse your cover. I was able to have mine delivered for $425 (found an online JDM trader, Amayama). It did take almost 3 weeks. But now you'll have a new switch, a new button, a new motor, and a new PLC.
Good luck!!
Good luck!!
#33
Sounds like this is my problem. I didn’t even think about checking the light and bought a new switch. Put the new switch in and no luck with the door but see that the light doesn’t go on. I must not have plugged in that cable you mention. Looking at the front of the radio, where would that cable plug in?
#34
I just bought my first 430. 2004. Extensive service history , well cared for. The only issue is the non functioning radio door. Stuck in the up position. I noticed that the push button does not light up with the head lights on. I assume that means no power to the switch. The previous owner mentioned that he had spilled a coke in the radio direction. He had the radio replaced but I believe the switch wasn't connected properly or is gunked up. Any thoughts on this? Thanks much.
#35
This is a common problem. Often, the cable did not get plug in. Easy fix, just remove the wood cover the console, you’ll see the small 2 wire cable with small white connector. Plug it in.
#37
I watched the video and the cable I see removed provides power to the cigarette lighter, not the switch for the radio door. At least that is how my 2003 is set up. I continued to pull out my radio and discovered I forgot to connect a cable to the connection in the back of the other two connections shown in my picture. When I found the cable and plugged it in, it provided the power to the left cable connection in the picture that leads to the door switch. That was the solution to why my switch wasn’t working…and I bought a new switch for nothing. Oh well, live and learn.
#40
#41
I found my issue. I disassembled the console area and noticed the door switch had fallen apart. The little circuit board that has the connector , light and actual switch was loose from it's plastic housing. Pressing the switch itself does activate the door just fine now. I just need to see how the switch is supposed to go all back together.
#42
#43
https://www.clublexus.com/forums/sc4...l#post11465463 (5 posts up)
