O2 sensor replacement
Old Jun 1, 2022 | 07:07 AM
WtSpyder's Avatar
WtSpyder
Default O2 sensor replacement
I have gotten the code for the bank 1 sensor 2 needing to be replaced. I have searched here and found a couple of threads. Found some YouTube clips as well. All say that you need to remove the seat and cut the carpet to get to the connector. Is this the way the service manual advised for replacement
Old Jun 1, 2022 | 11:18 AM
DshngDaryl's Avatar
DshngDaryl
It has been a long time since I saw the official procedure, but I think it calls for you to take out the front seat and pull the carpet back from the door sill. The good news is, YOU have experience taking out the front seat.
It maybe possible for you to disconnect the connector inside and tie a string to the end. Pull the O2 from the bottom and the string will follow the path under the carpet.
Attach the string to the new sensor end and pull up through the cabin. Hopefully the wire will follow the same path it came out.This may keep you from having to remove the front seat
Old Jun 2, 2022 | 10:26 AM
lugnuts's Avatar
lugnuts
I've had issue for several years on our 2004 and have lived with the instrument icons. Through the years have read a few with same issue and as I remember there are inputs and all talked about remove and replace from underneath for this specific sensor. Perhaps some more search will bring it up???
Old Jun 2, 2022 | 10:54 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
i did a search for ya and found this thread…
https://www.clublexus.com/forums/sc4...ors-sc430.html
Lexmex
RX - 1st Gen (1999-2003)
184
Sep 18, 2025 02:50 PM
evident
Jun 9, 2022 11:13 AM
dwlink
RX - 3rd Gen (2010-2015)
Oct 11, 2019 04:19 AM
ISFLexy
Performance
Dec 6, 2017 07:00 PM
pinoiryder
Jul 8, 2014 10:10 PM
