Coilovers
Old May 19, 2022 | 09:50 AM
DAVEB1980's Avatar
DAVEB1980
Default Coilovers
If I buy a set of coilovers do I need to purchase anything else to get them properly installed? Anything else I should do when getting coilovers installed?
Old May 19, 2022 | 10:29 AM
Harold57's Avatar
Harold57
It will depend on which ones you purchase. There are some out there that come with everything that you need. So you'll have to check with the seller/manufacturer.
Old May 19, 2022 | 10:34 AM
DAVEB1980's Avatar
DAVEB1980
Beside coilovers what would come with in the kit? Im clueless and want to make one purchase.
Old May 19, 2022 | 02:37 PM
Lawler999's Avatar
Lawler999
The coil overs should come with the adjustable wrench to alter the height settings, thats all there is
Old May 20, 2022 | 06:53 AM
DAVEB1980's Avatar
DAVEB1980
Ok that is waht I thought. Thanks for the help.
Old May 16, 2025 | 10:34 AM
fishinmagi's Avatar
fishinmagi
They should install the same as the other coilovers. Did you have any specific questions? there are a bunch of threads about installing them, and I've posted my experience/ tips as well
Old May 23, 2025 | 01:15 PM
doobs's Avatar
doobs
The MeisterR ZetaSport coil overs that I am installing right now have needed nothing other than pretty standard hand tools to install.
Old Jul 21, 2025 | 07:57 AM
Ken52's Avatar
Ken52
First I purchased right from Japan (MegaZip) the original OEM springs and shocks for that car (4 of each). That did nothing to correct the negative camber. Next I did the SPC 67510. Helped a little bit but required buying new toe in adjusters because the stock ones could not adjust enough from the camber improvements made from the SPC 67510. Finally I purchased adjustable UCA. That made me happy. -0.3 camber both sides. If I was to do it over again I would not waste my time with the SPC 67510 and instead just purchased the adjustable LCA. -2.3 camber is going to eat the **** out of the inside of your tires.
Second. Are you telling me that with all the alignments you had done, none of those idiots told you about the missing lip around the edge of the stock adjusters? Therefore they couldn’t do the adjustment but charge you anyway, right? So other than jacking your car up on the lift, what did you pay for?
tthomas543
Suspension
Jul 13, 2013 09:21 PM
speed6
Jan 25, 2011 07:47 AM
