5 Error lights.
Old Apr 21, 2022 | 12:28 PM
jimisbell's Avatar
jimisbell
Default 5 Error lights.
I started with a full slate of error lights (12 ?) and have gotten them down to just 5 left.
1) Low tire indicator (No pressure sensors in my new tires)...OK Im fine with that.
2) Windshield washer bottle ( Washers are working fine) Whats up????
3) Check engine light. (Dont know how to turn it off after oil change) ????
4) VSC
5) VSC (off)
The last two are an Oxymoron. How can it be both?? Tried pressinf the VSC button, no feel to it and nothing changes.
So what about 2,3,4, and 5 Any suggestions?
Old Apr 21, 2022 | 05:56 PM
DshngDaryl's Avatar
DshngDaryl
If your check engine light is on, the VSC lights are also on. It is Lexus's way to get your attention. Once you fix your Check Engine Light (CEL) then you can shut the other two off by following the directions in this post: https://www.clublexus.com/forums/sc4...s-no-code.html
However, I don't think a Washer Fluid Bottle would trigger a check engine light. Usually it needs to be something emissions related to turn the light on.
Old Apr 22, 2022 | 12:42 PM
Harold57's Avatar
Harold57
Have you run the codes on it yet? Check engine light could be a vacuum leak, depending on the code.
Old Apr 22, 2022 | 03:18 PM
GmanSC's Avatar
GmanSC
2. Low fluid? Headlight washer?
3. Clear the VSC light. Engine light will turn off.
Old Apr 22, 2022 | 08:06 PM
treefarmer's Avatar
treefarmer
Unexplainable Electrical Gremlins can also pop up when battery voltage through the system is wack. Look at your negative battery cable for corrosion and/or kinks. Make sure it has a strong corrosion free connection at both ends, not just at the battery.
Old Apr 25, 2022 | 07:19 AM
mandyfig's Avatar
mandyfig
Plus 2 on the battery reset, it does clear nuisance CELs.
Lawrence S
Jun 15, 2024 12:40 PM
Bmw745rims
Jan 24, 2022 07:54 AM
rc0107
Dec 9, 2020 07:00 PM
Sublime69
Nov 21, 2012 03:30 PM
sc430blue
Jan 26, 2005 08:42 PM
