Clock spring Spiral cable question
Old Sep 19, 2020 | 06:12 PM
Crowncouri's Avatar
Crowncouri
Default Clock spring Spiral cable question
Two questions is the steering angle sensor apart of the clock spring spiral cable? And would this also have possible connection as to why my turn signal lever does not return back to the neutral position?
Old Sep 20, 2020 | 05:16 AM
iolmaster's Avatar
iolmaster
I replaced my clock spring about 2 years ago. I don't know what a steering angel sensor is and no, the clock spring has nothing to do with the turn signal lever.
Old Sep 20, 2020 | 07:48 AM
DshngDaryl's Avatar
DshngDaryl
I am pretty sure that calibrating the steering angle sensor is what can be fixed with the "paperclip Trick"
Why do you think your clock spring needs replacing? Do your steering wheel radio controls work? Your horn? Do you have an airbag light on?
drrako
RX - 1st Gen (1999-2003)
Mar 25, 2018 08:05 PM
l33ks
Dec 9, 2017 06:58 PM
justablkv8
May 10, 2012 07:26 AM
Bender25
Nov 14, 2010 01:25 AM
