Trunk Rattle (Not from 808's)
Old Jul 15, 2020 | 01:34 PM
Lavrishevo's Avatar
Lavrishevo
Default Trunk Rattle (Not from 808's)
I'm getting an annoying rattle or kind of squeaking sound going over uneven roads when the top is up. It is not present when the top is down. It's definitely coming from the back. I thought someone mentioned about some kind of adjustment that cleared up their rattle. I looked with the top halfway but could not find anything to adjust. Any suggestions? I did treat my rubber seals with shinetsu, which is fantastic stuff to restore rubber molding. Did not help with this rattle.
Old Jul 15, 2020 | 02:18 PM
GmanSC's Avatar
GmanSC
One of our member reported that his back rattle turned out to be a loose wheel lug key.
Old Jul 15, 2020 | 02:36 PM
Lavrishevo's Avatar
Lavrishevo
I will double-check the tools don't think it's coming from this. When I say trunk it may actually be near the back window vs the trunk itself.
Old Jul 16, 2020 | 09:06 AM
DshngDaryl's Avatar
DshngDaryl
Can you give us more details? Any chance you can take a buddy on a drive and have them listen for the noise as you drive?
Old Jul 16, 2020 | 01:41 PM
doodles714's Avatar
doodles714
I recently experienced the same squeaking problem. I thought it might be my poly sway bar bushings but I pulled up the rear seat bottom and thoroughly cleaned and conditioned it before reinstalling. I think it was squeaking where it was touching the center console. Worth a try.
Old Jul 16, 2020 | 06:15 PM
Lavrishevo's Avatar
Lavrishevo
Yeah, I need to take a friend on a drive to see where it's coming from. It's somewhat new. Like the last few months. I swear it's not there with the top down. And I mean you can normally hear it driving slow or fast over uneven roads. I tried to duplicate the sound with the top down and I cannot hear it at all. Even in very a quiet atmosphere with the radio off. I'll try the rear seat idea.
I did double check the tools. It's definitely coming from the back. It sounds like like it's coming from the rear window area but as we all know it's difficult to pinpoint when driving.
Old Jul 17, 2020 | 05:47 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
I know you said you checked the tools...did you remove the jack?
if so, it will make noise IF, it is not extended in its holder.
hope I am making sense...can you move the jack when it is in its holder?
if so, extend it just a little or until it is tight in the holder.
Old Jul 17, 2020 | 07:54 AM
Lavrishevo's Avatar
Lavrishevo
Yes, jack is extended to lock in place. I did go through the obvious things pretty thoroughly that's why I was looking for some kind of adjustment bump stops or anything that would not normally be seen. When stopping the roof halfway I do not see anything like this. Also, I would think I would be able to hear it with the top down if persistent. To me, it sounds like the rear deck lid area. Ugh, so annoying try to find these things.
Old Jul 17, 2020 | 10:43 AM
WIL44's Avatar
WIL44
If you open the roof halfway until the rear shelf lifts up there is a round one and a half inch adjustable **** in the middle that you can move up or down. Turn it up a couple of turns and see if that works. Stopped the rattle I had.
Cheers
Steve
Old Jul 17, 2020 | 11:27 AM
Lavrishevo's Avatar
Lavrishevo
Cheers
Steve
Awesome, I will give that a try.
Will44 you are the man. This did the trick!
Old Jul 18, 2020 | 02:06 AM
WIL44's Avatar
WIL44
Brilliant, glad it worked.
Old Jul 23, 2020 | 03:27 PM
RK1679's Avatar
RK1679
10th Gear
After spending way too much time yesterday removing the rear seat, removing the spare/jack tray, trunk liner panels and several test drives in search for a mysterious rattle, I decided to try CL. I found this thread and tried the rear shelf **** adjustment. It worked!! I feel kinda dumb for all my unnecessary work but it's fixed. Gotta love ClubLexus.
Old Jul 25, 2020 | 07:04 AM
Harold57's Avatar
Harold57
RK1679, there is an amazing amount of useful information on this site. There have been an incredible number of really smart and talented folks on this site that have contributed for the past 18 years. There's all sorts of very useful information and tips here. Glad that you found your resolution here.
ayman01
NX - 1st Gen (2015-2021)
Oct 20, 2017 12:27 AM
Nasrul3698
Jan 11, 2017 08:40 AM
RC51TOFUMA
Dec 19, 2010 09:10 AM
ICEBERGS
Feb 27, 2005 10:51 PM
Blue98Gs3
Dec 22, 2003 12:59 PM
