Vibration on 2002 sc430
Old Jul 13, 2020 | 07:24 AM
Sparrow200's Avatar
Sparrow200
Default Vibration on 2002 sc430
I just recently picked up a 2002 lexus sc430 for my fiancé. The issue I am having is a slight vibration on the front end. At times it makes your voice shake and sound like you are talking into a fan. It seems to be more prevalent when the top is down. When you hit bumps it feels like it goes through the whole car, Not what you would expect from a lexus. The car has 49000 miles and was always maintained. This is a true California car and is in excellent shape and I want it to drive like a Lexus again. Also it seems to be at all speeds, smooth roads, Rough roads.
I am new here and your help would be appreciated.
Old Jul 13, 2020 | 10:59 AM
Raven01750's Avatar
Raven01750
Sounds like the struts are shot.
Paul
Old Jul 13, 2020 | 11:03 AM
Sparrow200's Avatar
Sparrow200
Thank you. I will schedule for struts. I just want it to be back to normal
Old Jul 13, 2020 | 11:50 AM
Raven01750's Avatar
Raven01750
Be prepared for some sticker shock. I just replaced all four of mine using Gabriel Shocks. I'm happy. But you have other options like adjustable coilovers or even factory stock which are ridiculously expensive. Take your time. Do some research on the site. Lots and lots of info on this subject.
Paul
Old Jul 13, 2020 | 12:12 PM
Sparrow200's Avatar
Sparrow200
My local alignment shop recommended kyb struts (Told me they are the same as oem) I am sure others have gone through this.
Old Jul 13, 2020 | 12:28 PM
Lavrishevo's Avatar
Lavrishevo
Steering rack bushings are also notorious for causing issues felt through the wheel / bump steer. There are other bushings that go bad as well. Particularly lower control arms 1 & 2. Also the lower ball joints. Don't throw parts at it. Get it diagnosed professionally. KYB is OEM though the tuning may be slightly different than factory. Ask the mechanic to check the rack for movement. This is an easy test.
With shocks and struts you can usually see oil leaking down the body.
Old Jul 13, 2020 | 12:35 PM
texsexlex's Avatar
texsexlex
....both suggestions are very good & I would also look at the rotors, since you're feeling the vibration, no matter the driving situation
Old Jul 13, 2020 | 01:24 PM
Sparrow200's Avatar
Sparrow200
I am having a shop look at it on Wednesday. I will throw these suggestions at the techs.
Old Jul 13, 2020 | 03:57 PM
Bgw70's Avatar
Bgw70
Veteran: Air Force
see post #40, if interested...all my parts are from Rockauto.com I really enjoy my 2002 SC430 again.
https://www.clublexus.com/forums/sc4...ive-maybe.html
Old Jul 15, 2020 | 04:11 PM
Wilson2000's Avatar
Wilson2000
I had the same issue when I bought my 2008 SC. I fixed it by getting rid of the run-flat tires. Tires could also be causing the vibration you are feeling.
Old Jul 16, 2020 | 12:49 PM
Sparrow200's Avatar
Sparrow200
The car is getting regular tires put on today. I will keep you updated.
The shop looked at the alignment and steering components and said it all looks great.
Old Jul 17, 2020 | 11:00 AM
Lavrishevo's Avatar
Lavrishevo
245/45 is the way to go.
Old Jul 17, 2020 | 11:02 AM
Sparrow200's Avatar
Sparrow200
New tires put on. Still a small vibration. Looks like it may be the rims. Anyone have any oem rims for sale?
Old Jul 17, 2020 | 11:18 AM
Lavrishevo's Avatar
Lavrishevo
Did the shop confirm they are out of round? All 4? There are companies that can fix the rims vs replacing for usually about $150 a wheel.
Old Jul 17, 2020 | 11:20 AM
Sparrow200's Avatar
Sparrow200
They showed me the front two were out of round because the front end was lifted. As far as the back ones I don't know.
Do you have recommendations for companies that do that type of work?
