Setting Memory Seats
Old Dec 9, 2018 | 12:27 PM
DJWLDW's Avatar
DJWLDW
Default Setting Memory Seats
I cannot seem to get the memory seats to set. I have checked all fuses associated with the power a 7.5 and a 30 on each inside panel and all is good. Set the positions you want have key on ON push and hold Set and then press the seat number you want. Am I doing something wrong?
Dennis
Old Dec 9, 2018 | 12:42 PM
Bgw70's Avatar
Bgw70
Veteran: Air Force
Dennis,
just a note...
post all of your pics in one thread...
also, plenty of info on resetting the seats brother...do a search.
read owners manual...
reset battery
move forward
move back
tilt forward
tilt back
set seat
Old Dec 9, 2018 | 01:03 PM
DJWLDW's Avatar
DJWLDW
Bgw 70
I tried uploading all the pictures in one thread but after the first one it would not allow me to upload another? I have read the owner's manual on setting the memory seats. I have had a Lexus LS for years and it is the same seat memory system only with 1 more button
Dennis
Old Dec 9, 2018 | 01:28 PM
DJWLDW's Avatar
DJWLDW
Ok I got it. I did not need to do the battery reset motion when I changed out the battery a year ago on the LS. Interesting that you need to reteach the seats after a battery change in an SC? Thanks for the tip Bgw 70. learned something new today. I was able to figure out how to transfer the contacts list from our phones into the 2 separate phone books. The phone system is not the same as in our LS
Dennis
Old May 9, 2019 | 10:32 AM
panoutz's Avatar
panoutz
What do u mean reteach the memory seats? Who?
Old May 9, 2019 | 10:46 AM
GmanSC's Avatar
GmanSC
Of course. You have to reteach your seats every time the battery is disconnected cause it’s memory will be erased.
Just like if you fell and hit your head to the floor. Your memory also be erased too!
Old May 9, 2019 | 10:48 AM
panoutz's Avatar
panoutz
Just had battery change and I can't reset my memory seats. They don't respond. Looked in manuel and couldn't find a fix. Any suggestions out their?
Old May 9, 2019 | 10:50 AM
panoutz's Avatar
panoutz
Misspelled words on purpose.
Old May 9, 2019 | 11:26 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
it was just pointed out to me that you own a 2009. By chance, did you purchase this car about a year ago from a couple in St. Augistine?
is it silver?
give these steps a try...
Originally Posted by JohnnyCake
Make sure you are in park with ignition ON. Assuming you are....
This sounds like the problem which occurs after power has been disconnected. The seats have to be "re-taught" their limits before the memory will work.
You should check your manual because I think different years have different procedures. Here's a couple posts from another thread:
What you have to do is move the seat back all the way forward using the power seat back switch until you hear a beep , then move the seat cushion back the entire way again using the power seat control, next move the seat cushion all the way forward using the power control. You can now put the seat in the position you desire and push set and #1.
1. Move the seat forward until you hear a beep.
2. Move the seat all the way back.
3. Move the seatback angle switch forward until you hear a beep
4. Move the seat back angle switch all the way reclined.
5. Set the memory now.
Old May 10, 2019 | 06:09 AM
panoutz's Avatar
panoutz
Thanks. I'll try that fix again. Looking in the manual, there's no fuse for memory seat alone, so I don't think it's a fuse. Tried google fix and that didn't work either. Maybe it's operator trouble!
Old May 10, 2019 | 09:38 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
Disconnect the battery before you try the procedure.
Also, is your car silver and did you purchase it from a couple in St. Augistine last year?
Old May 11, 2019 | 07:21 AM
panoutz's Avatar
panoutz
No the 430 is pearl white. Disconnecting battery didn't work, but did get it fixed. Thanks for ur help.
Old May 11, 2019 | 07:23 AM
panoutz's Avatar
panoutz
Reset seats again and it worked. Thank u 4 ur help.
DavidinCT
Dec 8, 2018 05:39 PM
foxrider68
Apr 12, 2016 08:05 PM
simplgreen
May 6, 2010 09:55 PM
johnnyreno
Mar 12, 2009 06:28 PM
dandd2
Jul 23, 2005 06:23 PM
