Homelink does not program
I am having an issue with programming the homelink as per the owners manual. Per manual you push the button on your transponder and homelink until light turns from slow flashing to fast flashing for about 20 sec.
In my case, when I push the homelink button - there is a solid red light. After I continue pressing it, the light turns into a slow blinking one and finally goes out. Light never turns into rapid flashing as per instructions.
has anyone come across something like this before?
I used the adapter just like the one in the link above. Because my SC's homelink would not sync with my door openers which were purchased in 2016. Works perfectly now so that adapter solved the problem for me. Hope it works for you too. Good luck !
The Homelink on our cars is not compatible with the newer door openers. The new openers have a rolling security code. There is an adapter that has to be used if you have a newer opener. If your opener is older then you are not using the correct sequence. I had to use one of these on a new opener that was put in recently with my daughter's 2000 RX. It worked right off the bat. See included link.
https://www.amazon.com/LiftMaster-85...melink+adapter
That sounds like a good summary of how it works. The adapter accepts the SC's homelink signal and retransmits it to the newer door openers in a way the new openers can understand.
You will need a free electric outlet in the garage to plug the adapter in. It has a small antenna and receives the signal from your car that has been programed from the remote that comes with the adapter. It then transmits the signal to the door opener. The only down side is, there is a slight delay and you may think it is not working. Not long, it just is not instant like we have been used to. Some have said that the range is not as long as car to opener. We haven't found that to be a problem. Range has been more than sufficient. Very easy and worked right away. Doesn't cost much either.
i was debating between this or just getting the wifi adapter for my chamberlain but seems less convenient to fumble for my phone and push the garage button on it each time. Plus the wifi adapter costs more than the homelink addon.
