Danny Dang
Old May 26, 2017 | 02:00 PM
crazyrc's Avatar
crazyrc
Default Danny Dang
Hi, I hope this is an easy fix.. my top was working fine then I took the interior apart to clean and paint then I put everything back together and now the top wont open. The red light on the open/close is lid.. can anyone helo
Old May 26, 2017 | 04:12 PM
kevin3344's Avatar
kevin3344
Check to make sure you haven't inadvertently hit the valet button in the glove box...also, be sure the privacy shade is seated properly like so...
Old May 26, 2017 | 04:28 PM
crazyrc's Avatar
crazyrc
the valet button should it be on or off? thanks
Old May 26, 2017 | 04:42 PM
kevin3344's Avatar
kevin3344
The button should be pushed in I believe...but you'll know because the light will blink 4-5 times and the top won't lower. Press it in and it should.
Old May 27, 2017 | 04:32 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
you said you took the interior apart, do you mean the trunk area?
if so, I bet you did not plug-in the trunk cover switch.
alyle1028
Jun 26, 2018 05:24 PM
Wbnjr
Apr 19, 2016 08:17 PM
ILowNslowI
Jul 24, 2012 02:48 PM
WhoDat
Aug 21, 2010 06:40 PM
young's 96
Nov 3, 2005 03:19 PM
