windshield washer problem
Old Jul 1, 2016 | 04:05 PM
gilfix1's Avatar
gilfix1
7th Gear
Default windshield washer problem
I have a 05 SC430 and there seems to b e a problem In the system. I can fill the reservoir and it doesn't seem to hold the fluid. I think there's a problem in the tubing - specifically in the connections. I think the clamps or whatever is used won't hold. Any suggestions?
Old Jul 1, 2016 | 04:48 PM
texsexlex's Avatar
texsexlex
..It could possibly be a hose that has come loose. You'll probably have to do through the driver side fender well, to get better access to it. If it's leaking, it should be easy to detect once you get to the unit
Old Jul 2, 2016 | 04:13 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
Agree with Tex. When i first purchased my sc, I had the same issue and it turned out to be loose hoses. Easy fix.
Old Jul 2, 2016 | 01:05 PM
Harold57's Avatar
Harold57
How long does it hold fluid? (Basically, how big of a leak is it?)
vuiskool
Apr 29, 2017 12:32 PM
SeanIS350
Mar 23, 2014 08:21 PM
schan1w
Maintenance
Jan 5, 2009 04:10 PM
renee
Sep 5, 2007 07:07 PM
tool24
RX - 1st Gen (1999-2003)
Sep 20, 2004 01:01 PM
