Driver side door cannot close when window is up
Old Mar 6, 2014 | 01:41 PM
jzwu's Avatar
jzwu
Default Driver side door cannot close when window is up
I guess the roof needs adjustment since my driver side door won't close if the window is up all the way.
Checked the roof and found there is a larger gap on the passenger side than on the driver side. That causes the unevenness of the roof, I think.
Just wonder if anyone else has such issues too. I am going to let the dealer take a look this weekend.
Old Mar 8, 2014 | 11:03 PM
jzwu's Avatar
jzwu
Took my SC430 in today for the passenger airbag recall and got a new 2014 ES350 loaner before I even asked.
Asked about the roof adjustment, the SA told me it would cost $200-300 for them just to look at it. I said no. Guess what's paying for all the new loaners? But the Lexus service is top notch indeed.
Old Mar 9, 2014 | 08:22 PM
416tt's Avatar
416tt
I dont think its your roof.. I think its your window.. did this just start happening recently? the only time i noticed my door wouldnt close with the window fully up was when the car was on a jack on one side meaning the whole body was flexing.. im sure without it being lifted from a side there wouldnt be enough flex for your door to not close.. must be your door or window
Old Mar 10, 2014 | 07:14 AM
kjcole's Avatar
kjcole
I agree. I'd be looking at the window adjustment first.
Old Mar 10, 2014 | 10:46 AM
Harold57's Avatar
Harold57
It is your window. There are stops down inside the door that tell the window computer when to stop going up. Look for my instructions on replacing the door's triangular weatherstripping to learn how to gain access and adjust it. It is not difficult and can be done in 20 minutes or so, but be patient and careful to keep from tearing up any plastic pieces.
Old Mar 10, 2014 | 03:27 PM
jzwu's Avatar
jzwu
This happened a while ago. I just lower the window a bit before closing the door.
Will check window. The roof has a lot of flex on jack stands and when going over bumps.
Old Mar 13, 2014 | 04:26 PM
1000hp's Avatar
1000hp
Probably needs to be re-timed
Old Mar 13, 2014 | 08:22 PM
jzwu's Avatar
jzwu
How do you re-time the window?
Old Mar 14, 2014 | 06:24 AM
tdedden's Avatar
tdedden
See post #19; "front door overhaul instructions" attachment; step #25 to adjust the window lean.
https://www.clublexus.com/forums/sc-...d-noise-2.html
Old Mar 14, 2014 | 09:35 AM
jzwu's Avatar
jzwu
Great. Thanks!
Old Mar 14, 2014 | 02:14 PM
jomo3640's Avatar
jomo3640
Also, when existing the car, don't push the window to close the door, use the door frame
woodranch
RC F (2015-present)
Apr 1, 2017 08:36 AM
MDames2
Dec 2, 2010 06:55 AM
blue43
Apr 1, 2008 03:29 PM
JJRHO
Oct 5, 2002 01:15 AM
