Squeaky Windows
Old Mar 31, 2013 | 07:03 AM
ceeps's Avatar
ceeps
Default Squeaky Windows
What's the best thing to put where the glass meets the rubber to stop squeaking when windows go down and up? Thanks for any suggestions!
Old Mar 31, 2013 | 08:03 AM
Taysdad's Avatar
Taysdad
I recently had this issue with the drivers side window of my 02. I found that just cleaning it very well made the problem go away. I used a detailers stick (basically a very large q-tip) with some Formula 409 on it to get deep into the rubber seal and clean it. I then used the same detail stick wrapped in a microfiber towel to get all the "black gunk" (technical term) out of the seal. Once I did this, the window stopped making any noises/squeaks. The only downside was I had to clean the window glass several times until all the 409 eventually evaporated (a day later) as it streaked the window. All in all, it only took me about 5 minutes to complete.
I did not put anything in the seal after I cleaned it. Perhaps I should have done so. I am interested in knowing if there is indeed something I should do to condition the seal other than just clean it.
Michael
Old Apr 1, 2013 | 03:11 AM
tromly's Avatar
tromly
Michael
great advice, will try it as I've never really cleaned the rubber seals. Great way to invest 5 minutes.
Old Apr 1, 2013 | 07:49 PM
jasone36's Avatar
jasone36
Mine only squeek when they're wet in my 2002, kinda embarassing
Old Apr 2, 2013 | 01:41 PM
FLYCT's Avatar
FLYCT
3M makes a product
http://solutions.3mindia.co.in/wps/p...indow-Channel/
JR
Old Apr 3, 2013 | 05:08 AM
ceeps's Avatar
ceeps
Originally Posted by FLYCT
can you buy this item in USA...where? noticed the web site is in India.
Old Apr 3, 2013 | 07:47 AM
FLYCT's Avatar
FLYCT
HUM?
Here is a 3M product that should work well and is available in the US
3M 08897 Silicone Lubricant (Dry Type) - 8.5 oz. : Amazon.com : Automotive 3M 08897 Silicone Lubricant (Dry Type) - 8.5 oz. : Amazon.com : Automotive
http://multimedia.3m.com/mws/mediawe...-&fn=08897.pdf
Applications
- Lubrication of plastic dash parts
- Door weather strips
- Window channel lubrication
- Lubricate door locks
JR
Old Apr 4, 2013 | 02:51 AM
townsville's Avatar
townsville
Greetings from Down Under, a cheaper alternative is glycerine (glycerol). It lubricates and refurbishes the rubbers usually cheap from pharmacy stores
pjarvis
GX - 1st Gen (2003-2009)
Aug 3, 2017 07:47 PM
kclineman
Feb 9, 2015 04:31 PM
aypues
Dec 27, 2014 05:05 PM
KonkBob
Nov 16, 2012 06:55 AM
HUSKERnKS
Apr 16, 2012 09:35 PM
