Window lines
Old Aug 1, 2017 | 08:37 PM
pjarvis's Avatar
pjarvis
Default Window lines
I'm looking for a solution for a problem with the these horizontal streaky lines that appear on the windows every time I put them up or down. Very hard to clean off also.
Old Aug 2, 2017 | 06:48 AM
mrblister's Avatar
mrblister
Have you got any pictures so we could see what your talking about.
Old Aug 2, 2017 | 08:32 AM
chiph9's Avatar
chiph9
I don't get them on mine.
Are they on the inside or the outside of the glass?
Chip H.
Old Aug 3, 2017 | 07:47 PM
Goosed's Avatar
Goosed
You most definitely either have felt strips that are either dirty or your weatherstripping is scorched. This will cause dirt marks across your window. I would suggest you start with the felt strips using a liquid base non carnuba spray was and a toothbrush to clean them up and wipe them dry. These felt strips ride along the window and so many times I see people lather their door panels with armor all or some other oil base protectant, and they get it on this strip. Causes marks as you are describing.
If if this isn't working then the actual rubber that meets both sides of the window is cracked and needs to be replaced.
aypues
Dec 27, 2014 05:05 PM
ceeps
Apr 4, 2013 02:51 AM
Entourage7
Jan 11, 2009 07:45 PM
mvallido
Aug 28, 2008 06:46 PM
bloo1987
RX - 1st Gen (1999-2003)
Jun 13, 2007 09:19 AM
